ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,879
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
The compression ratio spec is usually the mechanical compression ratio of volume at BDC divided by volume at TDC. There are a number of effects that can end up cramming more fuel/air into the cylinder than the mechanical ratio would indicate. There is a ram air effect in the intake where the mass of the air flowing in compresses the air in the cylinder slightly. In addition there is a resonant effect that is determined by the size of the intake tract. The opening of the intake valve causes a negative pressure wave to travel up the intake port and into the manifold. When it reaches a place where the cross section area increases (i.e. a plenum that feeds multiple cylinders) there is a positive wave reflected back down the intake tract. If it arrives as the valve is closing it stuffs more air/fuel mix into the cylinder. This effect is quite strong if the engine is designed for it. It's why two strokes with expansion chambers make so much power (it works on the exhaust too and the forces are stronger there). Modern LS engines have quite long intake tracts curled up into a log in the valley between the cylinders. Some '50s/60s Dodge performance v8s had two carbs one on each fender with long intake tracts crossing over into the opposite cylinders.
Last in a performance engine with overlap between exhaust and intake open periods there is a flow through effect where negative pressure on the exhaust side due to resonance pulls mix through the intake port. Taken to extreme this can make the engines run poorly at lower rpms where the waves are not in sync.
