PILOON
Super Star Member
Gee, all so simple.
Get 12 VDC to the glow plugs, heat them for a bit and she'll start!
generally its just a transistor controlled circuit, they can be burned out, but repairing them is generally specialized.I assume that derating occurs when the computer detects a fault. BUT will the computer RERATE if fault is fixed or is it a tech call out once derating occurs.
Querry: If ecu software is problem, will an "ecu flash" restore/update the corrpt software in the glow plug circut, or is problem physical damage on the circut board for kubota to be talking ecu replacement?
Had a JD 7430 that was running rough, it was given an "ecu flash" and the problem was fixed(somehow 2 injectors were mistimed).
good luck
The ECU reads the air and water temp sensors and they are both part of the glow plug wiring circuit and it has been stated that if the relays are bypassed, the tractor derates itself.
So how do you bypass all that and “simply install a switch”?
If that’s correct, that’s better, but still not realistic.Messicks new, not installed (if I found the correct part). Kubota: ASSY ECU (V61,KB, Part # 1H005-60204
I didnt see any on ebay right now, just the M-135GX board.
This is exactly what I was wondering. What happens if you don't disconnect anything, just run an additional line to the glow plugs activated through a momentary contact push button switch (as noted, you'll probably need to run it through an appropriately rated relay, since most switches are not rated for that sort of current). You might even be able to run the alternate power (or alternate ground depending on how it's wired) direct to the existing relay coil. MAYBE the ECU will not be ble to sense this, and things will operate as desired. However, if the ECU gets confused and derates, will it stop derating once you stop manually powering the glow plugs? If so, no big deal. You don't really need maximum power when first starting and warming up your tractor anyway.I assume that derating occurs when the computer detects a fault. BUT will the computer RERATE if fault is fixed or is it a tech call out once derating occurs.
Unsure, but those are my exact questions.This is exactly what I was wondering. What happens if you don't disconnect anything, just run an additional line to the glow plugs activated through a momentary contact push button switch (as noted, you'll probably need to run it through an appropriately rated relay, since most switches are not rated for that sort of current). You might even be able to run the alternate power (or alternate ground depending on how it's wired) direct to the existing relay coil. MAYBE the ECU will not be ble to sense this, and things will operate as desired. However, if the ECU gets confused and derates, will it stop derating once you stop manually powering the glow plugs? If so, no big deal. You don't really need maximum power when first starting and warming up your tractor anyway.
But on the other tractor they serviced, the ECU knew the GPs were out and set a code.There is no way the ECU would know the glow plugs are disconnected. If there is any feedback to the ECU, and I highly doubt there is, it would have to be a sensor somewhere that is triggered by the heat of the glow plug. If they are wired to work on a new circuit they will produce heat and the ECU will be satisfied.
However we know they are not working now and no light so obviously the ECM is not concerned with the glow plugs.
I edited the post. They are disconnected when the relay is no longer energized. That wire can not be the feedback. It is totally separate from the control side of the circuit.But on the other tractor they serviced, the ECU knew the GPs were out and set a code.
FYI: My GC2610 doesn't have all this stuff that's giving you problems but it did turn on a light that had no description in the owner's manual. The dealer didn't know so they called the factory. I was told my tractor did not support that light but on some other model it indicated a plugged air filter. I cleaned the air filter and the light went away.Correct!
And that’s another really strange thing.…The dealer took a look at what I had already done. I thought maybe they could shed a little more light on the problem, but they didn’t give me much more info.
However, they had an older M125X in with the same problem a few weeks ago. It had No glow plugs, but it DID show a code. They Ohmed everything and tried new sensors- no dice.
They suggested an ECU replacement and $6000 later, the older M125X had glow plugs again.
So the question is, why would the older, but similar size tractor throw a glow plug code, but mine doesn’t?
Or a block heater?A heated garage option available?
