ren1pa
Member
Greetings all.
I recently bought a Deere 3039R with the factory cab. I really do like it, but much to my disappointment, the SCV "joystick" is extremely difficult to use for the curl/dump function. I tried using both arms and it was still very stiff but NOT ergonomical for moving left to right at arm's length. (Neither a safe nor acceptable solution). As it turns out, the control does not directly open and close those flow valves, but rather controls a long slide cable like the throttle cable on a lawn mower, which travels several feet to the actual valve. This design is ok for lifting and lowering the loader which is no more than a push/pull motion of my arm which is ergonomically correct.
Unless the John Deere dealer has a remedy, I may have to consider returning for a different model or shop for another brand. .
Anyone else with the same problem? Any thoughts on this situation?
Thanks all,
ren1pa
Thanks all,
ren1pa
