Beware of the shop-vac trick when changing hydraulic filters...
   / Beware of the shop-vac trick when changing hydraulic filters... #21
That deck fitting has a tube that goes to the bottom of the waste tank into the fluid. As long as the vacuum hose doesn't reach the liquid it only pulls a vacuum on the tank. Only oil that will go into the vacuum tank is maybe some mist droplets caused by the agitation.
That was my experience with the "shop vac trick" method. No actual fluid stream comes into the shop vac but the bubbles breaking the surface makes for tiny droplets that are sucked up into the shop vac filter. It isn't much but I still had some shop vac filter contamination.. If the "shop vac trick" methods works for you, than that is cool. I just preferred to use the "stop up the vent" method. It works for me, and the loss of fluid from changing a filter is very small and predictable. It works for me, and I don't have to mess with getting the shop vac out and the duct tape or requiring an assistant.
   / Beware of the shop-vac trick when changing hydraulic filters... #22
I used this method once to change a leaking fitting on the bottom of a diesel fuel tank. The tank was about 3/4 full and I only lost a few drops. It worked awesome!
Absolutly do NOT try this on a gasoline tank as chances are very good that the electric motor will ignite the gasoline. If you insist on trying it have lots of insurance including on yourself.
KA-BOOM !
   / Beware of the shop-vac trick when changing hydraulic filters... #23
That makes sense!! Thanks.
   / Beware of the shop-vac trick when changing hydraulic filters... #25
You can make a pretty cool flame thrower using a brushed motor and WD40 ;)
   / Beware of the shop-vac trick when changing hydraulic filters... #26
Absolutly do NOT try this on a gasoline tank as chances are very good that the electric motor will ignite the gasoline. If you insist on trying it ...have lots of insurance including on yourself.
...have someone with a video camera with instructions to post it here. :LOL: :ROFLMAO:
   / Beware of the shop-vac trick when changing hydraulic filters... #27
Thanks for the tip, now I know why my shop vac acts like a leaf blower.😉
   / Beware of the shop-vac trick when changing hydraulic filters... #28
I wonder how much dust the exhaust from a dirty shop vac contains, and if it's now in the hydraulic tank?
I know... it's before the filter so (as far as I'm concerned) it's all good... I trust the filter will do it's job.
   / Beware of the shop-vac trick when changing hydraulic filters... #30
Plus the vac was blowing filtered air, it's not like the blower was reversed.
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
