What is the best house wash solution in 2021 for vinyl siding?
/ What is the best house wash solution in 2021 for vinyl siding? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
These things change all the time. What do TBN'ers recommend for a 2 story house in Northern Virginia?
I'd like to be able spray it on with a garden hose, BEING CAREFUL TO ONLY LET THE SOLUTION HIT THE HOUSE ON THE WAY DOWN!!
Then rinse it off USING SIMILAR CAUTION.
I know not to spray up and get water UNDER THE SIDING.
/edit
This is primarily to reduce algae buildup from last year. I've used Wet and Forget, self mixed Vinegar and water, etc. before.
I've got about 2,000 sq ft of surface to do.
/ What is the best house wash solution in 2021 for vinyl siding? #2
If you find a solution that doesn’t require scrubbing or even a pressure washer I’m all ears.
/ What is the best house wash solution in 2021 for vinyl siding? #4
Might depend on what you’re trying to wash off.
Otherwise take your pick of the cleaners available. There will not be any one “absolutely best” product.
/ What is the best house wash solution in 2021 for vinyl siding? #5
Before I got the pressure washer I would mix 1/2 cup TAP with 1 gallon of Clorox and put it in one of the hose attachments made for spraying pesticides. Spray it on, let it stay for a few minutes. Then spray it off with the water hose. Had to swap nozzles a lot but it worked.
RSKY
/ What is the best house wash solution in 2021 for vinyl siding? #6
I don't have vinyl, but have had good luck using TSP powder (trisodium phosphate) mixed with Chlorox on stained wood siding. I've always used a bucket and brush, however. If your new method leaves a few spots, I'd recommend this for them.
I've used Wet and Forget on the roof...worked, but took a long time to see results.
Good luck in your search.
/ What is the best house wash solution in 2021 for vinyl siding? #7
I have used 50% water with 50% bleach for 25+ years. Don't try to mix too strong or it will eat the finish off of your aluminum window frames. My house is one story so sometimes I get lazy and just wash with the pressure washer. Other times i go back to the old tried and true bleach and water. Sometimes it take two applications but I never have to scrub. Just spray it on, let sit a few minutes, and rinse.
/ What is the best house wash solution in 2021 for vinyl siding? #9
Do you have any of those dark spots that appear in the vicinity of where a spider has lived (spider poop)? If so try spray on oven cleaner, it worked great for me when nothing else did.
/ What is the best house wash solution in 2021 for vinyl siding? #10
RSKY
TAP?
/ What is the best house wash solution in 2021 for vinyl siding? #11
Get some stuff called Jomax. You add a little bleach and water to it. Not sure what else. The stuff in Jomax keeps the bleach from bleaching, only doing algae killing and cleaning.
/ What is the best house wash solution in 2021 for vinyl siding? #12
Cup of bleach, cup of degreaser like simple green or 409 added to 5 gallon bucket of water. Apply with car wash brush and leave on siding until it dries. Rinse with pressure washer on gentle setting. Leaving it on helps delay future algae, mildew growth.
/ What is the best house wash solution in 2021 for vinyl siding? #13
I had a couple bottles of something very similar, but already had bleach in it. Absolutely cannot remember what it was called specifically (was one of those things I picked up on clearance a couple years before I actually used it), but it did a fantastic job of cleaning and removing the (really bad) mildew. Came in ready spray bottles..
/ What is the best house wash solution in 2021 for vinyl siding? #15
Bob Vila has a couple of options on his website. I have used the bleach solution for years.
Whatever the recipe, your landscape around the house should be considered per his webpage.
/ What is the best house wash solution in 2021 for vinyl siding? #17
A typo on TSP.
/ What is the best house wash solution in 2021 for vinyl siding? #18
OG, my guessing isn't so good today . . .
/ What is the best house wash solution in 2021 for vinyl siding? #19
I have had great results with 30 seconds outdoor cleaner from Lowe’s. Mix it 1:1. In the past I used outdoor Clorox mixed the same and was fairly happy with that. I sprayed it on with a 25 gallon garden sprayer and then washed it off after sitting a few minutes with the pressure washer.
With the 30 seconds cleaner I applied it the same way, but washed it off with the water hose and I think it did a better job. Outdoor Clorox used to be about 6 dollars a gallon and the 30 seconds was almost 10 dollars, but Clorox went up and they are about the same price now.
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2012 Nissan AWD Rogue (A59231)
2012 Nissan AWD...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
