Time for a new portable generator
   / Time for a new portable generator #81
Can any tell me what size Generator is generally needed to run a Well pump. I just purchased a home and don't know anything about the well other than it's 240V 30amp breakers.
   / Time for a new portable generator #82
This is a good thread to go back and learn about everything you need to know about genny's because there is more than one answer and there are more questions to be asked.
At the least, I think you would want a 240v 30amp plug on the genny. Then add up the other things (watts) you deem critical to see how much more you tack on to the pump. Whether you want a standard genny or an inverter to better protect your sensitive equipment will affect the price as much as the brand you choose.
Good luck searching.
   / Time for a new portable generator #83
Well, it depends... (sorry, couldn't resist;)) Well pumps have large starting surges, with some folks recommending 2-3 times your running current, which isn't 30Amps.
The best way is to put a clamp on ammeter on your well pump wire (singular) and measure what the peak amps are. Multiply by 240 and give yourself 25-100% extra, and you should be good.
All the best,
Peter
   / Time for a new portable generator #84
All the best,
Peter
Thank you will take a look at this
   / Time for a new portable generator #85
I ran ours (also a 240V 30A breaker) off of a basic 3500W generator.
Occasionally the well would pop the generator breaker, but usually it managed just fine.
I also ran two refrigerators and a freezer off of the same generator, but the well definitely popped the breaker with those running. It's what I had, though, so typically we turned off/unplugged the non-well parts when we knew the well was going to run (ie, "time to flush the toilets!").
If it had been a 5000W generator I'm sure it would've been fine all the time, though the 5000W gneerator would've likely used about 50% more fuel (considering either one would've been running at the minimum level almost all the time with just about 500W constant load).
Make sure when you shop for a generator that it actually has a 240V outlet, regardless of if it's an inverter generator or not.
   / Time for a new portable generator #86
One local well company said he loves people that run wells on 3,000 watt and or cheap generators. After the last storm he made the most money he ever has…from pulling well pumps and replacing them.
their recommendation is never use less than 7,500 watt gen if running a standard well system. Some of the newer ones with computerized soft starters are alot more tolerant of smaller generators, but can be harmed by cheap generators.
pick your poison. He said one customer just paid over 6 grand to pull well pump and replace pump on deep water well. I guess the harbor freight generator didnt quite pay for itself this time.
   / Time for a new portable generator #87
For anyone interested in what a new generator does and what limits are acceptable, I did some digging tonight. Do your own research but this is what I found from a couple of sources that looked reputable. Here is one.
My takeaways were:
-60 Hertz +/-3 Hertz and 120v +/- 10% are limits for sensitive devices.
- Generators are set at the factory to run at 60-62 at no load so it will drop to about 60 under 50% load.
I got my Westinghouse 12500 today and started it up using propane and then plugged in my meter under no load. Hope this helps.
I have a 6900 running watt generator. I have an interlock and sub panel installed by the electrician.
well runs just fine off of it. However I would not want to run the well, coffee pot, fridge and pumps for the boiler all at the same time.
for those of us who are on well water we need a generator quite a bit larger than those not on well water.
fortunately the heat portion of the boiler and the water heater are natural gas fired.
   / Time for a new portable generator #89
I have a Porter Cable Honda powered 3500W generator (non inverter).
Though I have never used it for such, I fully expect that it will start and run my 1HP Goulds shallow well pump.
All other electric items will be off when the pump starts/runs.
I suppose I should test it.
I also have a 6500W Honda.......just in case!
   / Time for a new portable generator #90
I bought a Champion 100520 last year to deal with the PSPS in California, and other outages as well. I am totally happy with it! Always starts with the push of the switch, even if left to sit for 6 months. The starter battery holds it's charge well. I wanted inverter so as not to fry any of the numerous electronics it powers while on. Why take chances? If a device is operated on dirty power, excess heat can be made in the device, potentially damaging it.
At the time, I wanted a dual-fuel inverter generator, Westinghouse was at the top of the list. However, none that were CARB legal could be found anywhere I searched. No one would ship a non-CARB legal model to me in the Goldilocks State. It was a time of a dearth of generators that fit my needs for output and clean power.
When I saw the 100520 for sale, I jumped on it. It's gasoline only, to be honest I have not missed the ability to power it on propane. I am fortunate to have a source of ethanol-free gas nearby, and that is all I have ever used in it. Just recently we had an outage due to equipment failure. The tank was half-full of 6-month-old gas. I hit the start switch, it fired up instantly.
It's noisy, but not that bad. I run it near the house and can hardly hear it with the windows closed, which I do to keep exhaust out.
As far as hooking it into the house, I contacted two electricians to update my power panel to accommodate a whole house switch. They both flaked. So I made a suicide cord to plug the 240V into an unused dryer outlet, keeps the well and anything else (within reason) running just fine. I am beyond religious in disconnecting the house from the mains, and in never exposing live metal on the suicide cord. It requires mindfulness, but I've never had a problem. I will say that my main panel connects to the utility power via an ancient setup with cartridge fuses, so when I pull those I have very clear visual confirmation that the utility is disconnected.
Also needed using this method of connecting is turning the dryer circuit off when not actually transferring power from the generator into the house wiring.
Please, please do not use a suicide cord unless you fully understand what you are doing and why, and will always abide by the proper procedure to connect and switch things. It's just not worth killing yourself or others.
A good source of information on portable generators is GeneratorBible.com - Leader In Portable Generators Stats & Comparison
2012 FREIGHTLINER CORONADO 122 (A55745)
2012 FREIGHTLINER...
2014 Nissan Murano AWD SUV (A55758)
2014 Nissan Murano...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
Giyi 72" Grapple (A53316)
Giyi 72" Grapple...
2019 John Deere XUV560E 4x4 Utility Cart (A55787)
2019 John Deere...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
