Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 21,688
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Your money, but I will say buying the smallest possible tractor to do the job usually results in a trade-in for larger down the road.I think i'll start with open cab. I have a leanto on the property that i want to park it under and it wouldn't fit with a cab on it. Figure I can always cobble something together later if i decide i need to defend myself from the snow. Parking and navigation between trees on the forest trails is what makes me gravitate more toward trying to buy the smallest tractor that's capable of the work i have. A larger tractor than i truly need would just mean wasted fuel, higher upfront cost, higher implement cost, and higher parts costs down the road. I'd rather spend an extra hour per project and possibly be a little frustrated than waste the money -- as long as the job gets done.
I'm still trying to sort it all out, but it seems that the tractor market is kind of similar to the power tool in that there are a handful of manufacturers that make several major brands.
LS makes models for -> New Holland, Case + 8 others
TYM makes models for -> Branson, RK, Mahindra, Zetor + 10 others
Yanmar makes models for -> Deere, Zen-Noh
Daedong makes models for -> New Holland, Bobcat, Cub Cadet + 5 others
Mitsubishi makes models for -> Case, Mahindra, Cub Cadet, IH+ 3 others
Tractors built by other manufacturers
tractors.fandom.com
Another way to look at it is New Holland buys and rebadges tractors from several other manufactures: Al-Ghazi, Buhler Versatile, Iseki, Landini, LS, Shanghai, Shibaura, Turk Traktor
List of tractors built by other companies - Wikipedia
en.wikipedia.org
Though, specs can certainly vary between what the manufacturer makes for themselves vs what they make for another company. For example, LS may make their own MT125 better or worse than how they make the NH Workmaster 25s. However, either way, if LS were to fail then you'd be out of luck with repairing a Workmaster tractor. Similarly, if Daedong were to go out of business then there would no longer be parts for the NH Boomer line. Kind of makes you have to think a bit about the perspective of which ones are the real 'off brands'.. is it New Holland, or is it LS/Daedong? Kind of like how some people are fan favorites of CubCadet and may say to avoid TroyBilts because they've had nothing but bad experiences with them.. yet they're both made by MTD. We all tend to develop or own brand favoritism, whether it is logical or not.
I'm mostly interested in looking beyond brand prestige/favoritism and simply finding the best value available. As i continue to research I'm finding that just about all of the major brands should hold up well over time and i feel I should be more concerned about features/capabilities than the sticker or paint colors. Getting the objective information about capabilities is a bit tricky though. Some people say you shouldn't bother clearing snow from a long driveway with anything less than 40HP and an 8 foot blade, yet others will use a walk behind blower because they're not worried about efficiency.
Up front cost on an older/bigger tractor are probably same as a newer/smaller tractor.
Don’t always count on larger tractor parts being more expensive, either. Filters for my Case-IH are cheaper than for my smaller Kubotas. But yes, tires cost more and usually they hold more oil in transmission, engine, rears, etc.
As far as fuel consumption cost goes, generally bigger tractors consume more. However, if a bigger tractor with an 8’ blade can grade your driveway in 1-2 passes versus a small one with a 5’ blade requiring 4 passes, the fuel consumption should be pretty comparable. Same goes with a bigger tractor with an 8-10’ bush hog making less passes than a smaller tractor with a 5-6’ bush hog.
when shopping brands, take a look around the back of the dealership. Observe how much road service equipment they have and how big their shop is. Usually (not always) more is better. Research the dealer. I buy from service-oriented dealers rather than lowest price. Just one service call/repair can make all the difference in the world. One of the dealers is massive, the other is on the smaller side, but the one thing they have in common is they LIVE to repair equipment quickly.
Just some things to think about.
