Bad boy compact tractors?
/ Bad boy compact tractors? #1
tman1020
north west indiana
Bobcat ct225 and Bad Boy zero turn
/ Bad boy compact tractors? #2
Do you like Bad Boy products?
Have you had a Bad Boy Mower?
/ Bad boy compact tractors? #4
Yes they made a partnership with Kukje to sell their tractors as ruffdog pointed out above.
They are rebadged Branson tractors up to 35HP.
/ Bad boy compact tractors? #6
This would have been a good opportunity for a joint venture with Power Trac. Instant dealer network, and similar repair skillsets.
Yes I had a bad boy mower. It was a commercial grade mower. I did not care for it. Lots of small problems. To be fair I bought it used and it was pretty abused when I got it.
/ Bad boy compact tractors? #9
One has to wonder where the saturation point is in the SCUT/CUT market?
/ Bad boy compact tractors? #10
With the current flight from cities to somewhat rural areas, there just might be a long term market.
/ Bad boy compact tractors? #11
They make good heavy duty 3pt rotary cutters. The 5 foot cutter weighs 718 pounds. Local dealers couldn't move them and ended up in auctions cheap. Other than lawn mowers don't see any equipment locally.
/ Bad boy compact tractors? #12
Just purchased a 4035 Bad Boy cab HST Tractor. Did some research and this tractor fits what I need it for and in comfort. As long as it performs as expected I am not to concerned as to the origin of its components. I like the layout of it cab and it is about time someone put an ignition switch on the top of the control panel and not hidden somewhere down below or on the side! Much quieter running, even with cab doors open than my previous tractors.
/ Bad boy compact tractors? #13
Congrats on the new toy. Looks great!
/ Bad boy compact tractors? #14
Congratulations! I am sure that tractor will serve you well! I like the color!
/ Bad boy compact tractors? #16
Another rebranded tractor venture. Good luck.
/ Bad boy compact tractors? #17
Congrats!!!
Mike
/ Bad boy compact tractors? #18
Looks great. It seems to be hiding a John Deere in the background!
MoKelly
Yes, that is a 23 year old JD with a back hoe.
/ Bad boy compact tractors? #19
Who built it?
/ Bad boy compact tractors? #20
It is assembled in Batesville, AR. about a two hour and one half hour drive from where I live.
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
UNUSED SDLANCH SDLL60 STAND- ON SKID STEER (A64280)
UNUSED SDLANCH...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
