Turf tires vs r4’s
   / Turf tires vs r4’s #1
RickSr
Mahindra Emax 20s HST
I have a Mahindra emax 20 hst. I have r4’s tires on it currently, I find them very hard riding. Does anyone know if regular turf tires would make for a softer more comfortable ride ? Thanks in advance for your response.
   / Turf tires vs r4’s #5
Yes, make a difference. But will you feel it much? No
If you do anything with your FEL don't go to turf tires.
Well, I understand what you are saying but you can buy them with either tire with a front end loader and they don’t tell you not to use it with turf tires ?
Someone told me they had r4’s and switch to turf and they said it made a big difference, like he has suspension. I don’t know.
   / Turf tires vs r4’s #10
Had turfs on the first series 2 JD. Had LOTS of front tire problems. Have had R4s on the 1025R and now on the 2025R. No tire problems at all. Yeah, a bit harder riding. Haven't tried lowering the pressure on the rear ones. Was suggested to another OP who brought this up. DO NOT lower pressure on the front ones though.
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
