Who Broke The Bridge?
   / Who Broke The Bridge? #181
The break looks rusted at the seam...probably been that way for at least some time before detection. Lucky.
   / Who Broke The Bridge? #182
It was broke for quite a few years if go backwards looking at older posts here. The bridge inspector was fired but it seems the state inspection system in need need of some updates...
   / Who Broke The Bridge? #183
Repair plan.
Bruce
   / Who Broke The Bridge? #184
Crack was not complete through the box beam. Bottom plate was only 20 percent cracked.
Fired inspector add job of looking entire tie within arms reach. He lied about completing entire length. He deserves to be fired. Video has same cause for crack as my original opinion
   / Who Broke The Bridge? #185
I just watched practical engineering video again and that beam sure looked completely broke off in it. Of course it is a high tension member which confuses me how the bridge could stay up, if it was severed*.
* doesn't take much
   / Who Broke The Bridge? #186
ArlyA
They do not show the bottom of the beam in the video. Top and sides were completely cracked.
   / Who Broke The Bridge? #187
Photo of the bottom of the beam in the article here. There is a reason why it is described as cracked: The bottom seems mostly intact despite the 1.5" gap and 2.5" displacement at the top.
https://www.thedrive.com/content/2021/05/v3.jpg
An Ar-DOT 2019 photo makes it look like the crack started at the bottom edge.
All the best,
Peter
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
3PT BOOM POLE (A52708)
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
More info coming soon! (A56858)
More info coming...
