Estimate of the Cost of Welding
   / Estimate of the Cost of Welding #1
katyhorn
Member
Smithville, Texas
BX 2680
Hello Everyone,
One of the braces on the mower on my riding lawnmower is breaking off and needs to be rewelded. I've never had this done (newbie at working land) and have no idea how much it costs for say a 3-4 inch "re-weld" or prep and weld. Any idea (range) of what I should be paying for something like this? Thanks!
   / Estimate of the Cost of Welding #2
It would only take a few minutes. Whatever minimum the shop is charging.
Here is a pitcture
   / Estimate of the Cost of Welding #7
Around here, if you take it to a metal shop or welding shop, the minimum is $30. Atrocious! Took 3 minutes to weld a bracket that cracked. I had already prepped it by grinding the edges and cleaning it up.
So I went to Harbor Freight and bought a $199 welder. Do all my own repairs now, and I'm fabricating a drive over grate for a trough drain. Spent $21 on rebar, will save a couple hundred by making one instead of buying one.
   / Estimate of the Cost of Welding #8
30$ is atrocious? At least you found a hobby out of it. Nobody touches anything for under a 100 on a walk in job by me that I know of. BTW, I weld many of these Husqvarna decks. 46"? No gussets or other reinforcement normally required unless the housing is starting to deteriorate. They will weld in both sides of the bracket and hopefully hit the other side as well.
   / Estimate of the Cost of Welding #9
Yeah, if you have any interest in metal work at all buying a cheapie welder will more than pay for itself in the long run, the Harbor Freight welder mentioned above is likely the new tiny Titanium jobbie and I will agree, it is nice, throw in a $40 auto darkening hood and you're in business...
But if you have no need for that I do agree with others, either find a neighbor or try shops and expect $50 to $100 anymore...
   / Estimate of the Cost of Welding #10
Find neighbor with home/shop welder and give him a 12 pack of adult beverages....
IF you were closer I would do it for 2 6packs of A&W root beer...
If a neighbor asks if I can weld something for them I tell them to do the prep and clean the areas needing welding and to remove all paint and rust. I won't touch it if they can't be bothered to clean and prep. If they want to thank me with beers I'm ok with that!
If you make it easy for the weld shop and show up with everything clean and prepped and ready to go they will usually give you a break. If you show up with a dirty toilet job you are going to pay full rate T&M.
Don't be a dumb@ss and show up expecting people to do your hard dirty work and get paid nothing because you don't value or respect other people's time.
Giyi Root Grapple (A53316)
Giyi Root Grapple...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
16' Cattle Guard (A53316)
16' Cattle Guard...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2015 FORD E350 16FT BOX TRUCK (A56129)
2015 FORD E350...
2020 Ford F-350XL (A53314)
2020 Ford F-350XL...
