How do you know when the ground is settled enough for concrete?
   / How do you know when the ground is settled enough for concrete? #1
tomplum
Elite Member
PNW
XJ2025H
We had a sloped area of the yard that was partially an old building torn out which had just a gravel pad. Last summer, we filled over this with close to 3' of mixed dirt that had a fair amount of clay and expanded that area. Built a solid 60# block retaining wall around that. The goal is to build a 120 sq.ft. building with a concrete slab.
   / How do you know when the ground is settled enough for concrete? #2
You would have had to put the dirt down in thin layers (aka, "lifts") and compact each one in order to have any hope at proper compaction. Did you do anything like that?
Around here the clay soil is useless for any sort of base since it won't compact well once disturbed. I have to bring in a "compactable fill" material that is a mix of sand, gravel, and clay. I spread that in 1-2" layers then drive over each one a lot. I doubt it's perfectly compacted but it's been good enough to support concrete slabs for vehicles without any cracking.
The key is to understand the load distribution on the concrete slab and then verify the soil can support it. You should be able to estimate the ground load (in PSI or PSF) needed to support the slab, then do a very simple test to see if the soil meets that. The test would involve placing a weight over a certain bearing area and see if the ground supports it without compacting or sinking in.
   / How do you know when the ground is settled enough for concrete? #3
Not an engineer, but in my distant memory, seems like a non compacted fill was considered "compacted" after two years for some purposes. The compaction requirements would be dependent on the amount of weight to be supported. I'd imagine your 120 s.q. ft. building would probably be fairly light load. A 4" concrete slab with reinforcement will hold a bit of weight, of course 6" will hold more. Then the use of the building, if it was to hold a water tank that large, or rakes and shovels.
No, we didn't compact it in layers. Though I thought that far ahead, didn't have the time or energy for that. The main reason for the slab is to keep a clean area. We will put a couple freezers in the shed and a stainless counter for like a brew area. I have enough pavers to do the whole area if I wanted, but then I would have to be smart enough to anchor a building and keep it rodent proof.
   / How do you know when the ground is settled enough for concrete? #5
I poured a 100 sq. ft. slab on top of some tall Kentucky Bluegrass 15 years ago and everything settled evenly with no problems.
The contractor ordered concrete for 3 small jobs and one of them canceled so he needed a place to dump 1.5 yards of concrete. I nailed four 2x4's into a frame and laid it by the fire pit then went to help pour the driveway extension project.
I wouldn't worry about your 10x12? slab, just pour it and let it cure for a couple of weeks
   / How do you know when the ground is settled enough for concrete? #6
You in a big hurry? You can try puddling. It doesn't work in every scenario. What you do is flood the fill dirt with water. A garden hose will do. Just keep moving it around and soak the fill and it will settle. This will eliminate air spaces and air pockets in the fill. You will probably end up adding more fill. You'll need time to allow it to dry out.
From a construction article:
" You're correct that the dirt in the center of the garage area is solid fill. Mother Nature, over time, does an amazing job of compacting soils. Rainwater plays an important part of this process. Adding water to fluffed or disturbed soil will go a long way to accelerate natural compaction of soil particles.
When I was still actively building, I would go to great lengths to water the fill soil in utility trenches and around the outside of a new home to get the soil to settle faster. Many builders don't take this extra time."
I used this technique with a large garage I built and never has a concrete problem
   / How do you know when the ground is settled enough for concrete? #7
All depends.
Yeah. I build a shop that was 12x24 in 1987 on a slope that had fill on lower side. red sand fill, and really not compacted. 4 inch slab. over the years a lot of the fill was dug out by animals and water. Slab never cracked.
Fast forward 20 years. Built a 30x30 metal building. Only one corner had any fill. and was better compacted. about 6 months after fill and pour. again 4 ft slab, this time a slight 6 in footing and sidewalk down long side. Slab cracked at fill line and all along the sidewalk slab joint. Better prepared but didnt matter. These two were 20 feet apart..... a lot is the concrete strength also
   / How do you know when the ground is settled enough for concrete? #8
Oh, and my daughter is building house on good slope, cinder block walls filled with rock and loose fill with 12 inch footing, 24 inches wide. Walls filled with concrete, 4 plus in slab. it ain't moving
   / How do you know when the ground is settled enough for concrete? #9
My opinion ... the size and expected load aren't significant enough to be concerned about. Embed wire mesh, and you'll most likely never notice an issue.
I guess you could get a load of crushed rock and rent a plate compactor for a weekend if you wanted to.
Thanks guys. I had the thought of renting a jumping jack, but then there is vision of a sudden left turn and over the retaining wall...
Informational Lot - Financing (A56436)
Informational Lot...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2022 FORD F-250 (A58214)
2022 FORD F-250...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
