Who Broke The Bridge?
   / Who Broke The Bridge? #21
Totally unrelated, but how do they set the rivets on a beam like that?
The rivets were heated up and installed from inside the beam. The exterior side was then hammered to form rivet head.
I inspected major bridges for over a decade
   / Who Broke The Bridge? #23
Looks like infrastructure repair time.
Barge traffic from the east might divert through the Tenn-Tom. I'm about 2 miles from it. My relative who lives right on the waterway said barge traffic was up yesterday. I often hear their horns as they lock through.
   / Who Broke The Bridge? #24
I must have a guilty demeanor. When I read his headline the first thing that I thought was "It wasn't ME!!!!"
   / Who Broke The Bridge? #27
Interesting failure. When a structural member breaks clean right near a major connection like that, it sort of suggests cyclical loading or vibration fatigue. The ability for the member to flex and relax is constrained when you get into short range of a connection.
   / Who Broke The Bridge? #28
Ahhh, a couple of guys on ropes and a couple mig welders could fix that right up!
......not..... that took some stress.
   / Who Broke The Bridge? #29
At WELD?
They used rivets.
Yes, minimal rust from what I saw.
The box beam is made of four steel plates joined by longitudinal welds. The pieces are bolted together. If you look close you can see the hex head of the bolts at the connection
   / Who Broke The Bridge? #30
At a weld? There's no weld at that break. That bridge must have been one of the ones you "inspected".
Longitudinal weld for length of member.
I have been the lead engineer for inspection of several bridges across Ohio river and numerous other bridges.
Cracks can grow from fraction of an inch to completely through member in hours.
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2002 International 9200i Truck (A55302)
2002 International...
2021 Toyota Corolla LE Sedan (A55758)
2021 Toyota...
