airbiscuit
Super Member
- Joined
- Aug 28, 2004
- Messages
- 7,450
- Location
- NW Wisconsin
- Tractor
- New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
Oh, forgot to mention "jam switches". Every lighted closet including the pantry should have jam switches. Greatest invention ever.
Yes. The switch is a push button located in the door jamb, hinge side. Open the door, light on. Close the door, light off. Genius!!!!
Wow. I never found them hard to install at all. I ran the wire just like for a normal switch. Carpenter installed door. I cut in switch hole and hooked it up. If your carpenter charges you $100 to install one you might need to change carpenters.![]()
So installation with a drill, oscillating cutter and a chisel (for the faceplate)? Not the hardest thing to do, but kind of futsy (see the 3 minute mark of this video)
