What kind of Box Scraper?
   / What kind of Box Scraper? #21
It looks similar to mine. Mine is barely bigger than the tractor's width and when turning, I can't cover the entire track the tractor leaves. Mind you, it's not that much and easily fixed with a rake afterward.
   / What kind of Box Scraper? #22
BTW, I'm thinking of adding some washers between the 3PH lower links and the lynch pins so the lower links are always against the box scraper frame and not some distant from it. My thinking is there are less chance at bending the pins if they are closer to their attached points.
   / What kind of Box Scraper? #23
I have a JD 4300 and need to purchase a box scraper for it. Any recommendations for a good quality scraper?
I’ve been looking at a Gearmore Box and a Frontier B2060. What’s better in your opinion? Thanks
We need an update, have you decided on a box blade?
   / What kind of Box Scraper? #24
Been considering a box blade. I have a .2018 kioti dk5510 tractor, first I want to put a hydraulic top link on then buy a box blade. What’s a good size? Just wide enough to get past the rears?
   / What kind of Box Scraper? #25
If your road is straight, it will work but that's what I did but my road curves. In the curves, the box is not wide enough to cover the full tracks. If you don't mind taking a rake to remove the tractor's tracks, then it's all fine. That's what I did.
   / What kind of Box Scraper? #26
My road is curvy and hilly. Been digging out rocks to try and smooth it.
   / What kind of Box Scraper? #27
Same here and why I bought the box grader. Got rid of many boulders with it.
   / What kind of Box Scraper? #28
I’ve dug out some boulders that look like rocks on the surface but ended up being as big as a 55 gallon drum. Dug out 2 of those so far. Stump bucket to pry under then use my grapple to move them.
   / What kind of Box Scraper? #29
Wow! That will leave quite a dent in the road... But nope, mine were more like a 5 gallons tanks.
   / What kind of Box Scraper? #30
Very rocky where I’m at in southern Indiana. I have boulders lining my road as big as cars. Out in the woods there is one as big as a small house I put a ladder on to climb and deer hunt off of.
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A57192)
THRESHOLD 30"...
2015 JLG M600JP TELESCOPIC MANLIFT (A52707)
2015 JLG M600JP...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
