L3010 GST will not shift out of neutral
   / L3010 GST will not shift out of neutral #1
ltlbull
So I am not sure if these problems are related, but I noticed for the past couple of weeks that the steering has gotten stiff (harder to turn). Hydraulic fluid is at the correct level, bucket and 3-point operate with no problem. And now today I can not shift from neutral to 1-8. It is stuck in neutral. I can shift from forward/neutral/reverse on the column, but that is it.
I was going to try and disengage the shifter cables from the rotary valve to try and isolate the culprit, but was hoping someone here has had a similar problem and hopefully a solution.
Any help would greatly be appreciated. Thank you.
   / L3010 GST will not shift out of neutral #2
Does the PTO function as it shoud??
Yes. I found the problem....it is one cable of the cable shift assembly. I took it off the tractor by removing the rotary valve housing, then I separated the upper housing that the shifter attaches to and removed the cables. The white upper cable going into the rotary valve is frozen within the cable.
So here is the issue: You can't just replace this $10-$50 cable, you have to purchase the whole cable shift assembly from Kubota for $680.00!!! Unless someone knows where I can source these cables? Right now I am trying to free it up.
Thanks.
   / L3010 GST will not shift out of neutral #4
Yikes! I hope you get it freed up.
That is awesome! I searched and searched and could not find anything! Thank you so much! Going to give it a try. :)
   / L3010 GST will not shift out of neutral #7
You could probably post on that thread and get in contact with the guy who did it.
Does anybody know how to re-assemble the rotary valve without the two indent balls falling out? It is killing me. Here is a picture with the springs. The balls are supposed to stay on the springs somehow while you insert the indent plate. I have no idea how.
Thanks.
   / L3010 GST will not shift out of neutral #9
No help for your question, but posting this for posterity.
   / L3010 GST will not shift out of neutral #10
I'm not sure thus helps.
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2-Stertil Koni lifts (A50775)
2-Stertil Koni...
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
Bobcat 72" Skidloader Bucket Broom (A50775)
Bobcat 72"...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
