Now that the snow blowing season is over,
   / Now that the snow blowing season is over, #1
SylvainG
South West, Qc
Kioti LK30
What should be done to prepare the blower (3PH) for storage?
   / Now that the snow blowing season is over, #2
Are you sure...really sure. ;)
Check over good for loosen parts,grease,touch surface with no paint,if outside storage keep off the ground also from elements,if hyd. connections cover with plastic bags etc....it's start.
Lol, nope but if it snows, I'll use the ATV. No need to take out the big guns in March :)
Thanks. It's outside, covered but I didn't think about raising it from the ground. Sounds like a good idea.
   / Now that the snow blowing season is over, #4
I touch up the paint , grease , oil the chain and spray it with Fluid Flim also grease the pto shaft and leave it in two pieces so it does not rust solid...
   / Now that the snow blowing season is over, #5
Oh, good idea, I didn't think of that one, thanks :)
   / Now that the snow blowing season is over, #8
My you get 4 feet of heavy wet snow for saying that snow season is over now!!!o_O:ROFLMAO: Or live in Denver CO
   / Now that the snow blowing season is over, #9
I didn't use my blower this year, so it's all set! I did make a Dollie for it so I can move it around in my garage. (2) Harbor Freight 24x16" dollies with 4' 1x6" boards connecting them.
   / Now that the snow blowing season is over, #10
I only used mine 4 or 5 times this year. What a miserable snow year. All the talking heads on tv had warned us about a abnormalily cold and wet year prediction. Wrong again.
almost wish I never chained up the tractor.
but every year I power wash plow, chains and blower After season is over. Then I bring the plow and blower into shop to lube and paint bare metal. My units are 10 years old now and still look great.
the only thing I’ll do different this year is I have to repair a couple of holes showing up in snowblower drum area...caused by rocks being swished around . Stupid rocks. I’m going to cut out the metal and replace it with 8 ga steel. Hardest part is bending the steel. I practiced with a scrap piece and the roller handled it great. Its th3 thickest piece of steel I ever tried to run thru the roller.
207269 (A52708)
207269 (A52708)
16 BLADE DISC HARROW W/ 1PT HITCH (A52708)
16 BLADE DISC...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
EZ-GO golf cart (A56859)
EZ-GO golf cart...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
