Seven Gables
- Joined
- Jan 30, 2019
- Messages
- 617
- Location
- Northern lower Michigan
- Tractor
- jd 5115m , Ford 545D, Kubota M8540, NH t4.105 , Ford 5030, Ford 4830, NH TN 95FA, Volvo EC60E
Ahh the cobbleko, been hoping you add some pics, thanks. Hmmm is right. When I look at it I'm trying to justify or not justify the hours. Tracks if original?, look to be at ballpark 75% from pics best I can see, that adds up correct. Can't see the cutting edge on blade but the top side looks pretty straight , does it appear to have some original paint still on the front of it? Bottom half of the track frames have seen some pretty good abrasion I would say for less than 900hrs. Boom and arm look to have taken some hits but not too bad. Do you know what it spent most of its life doing? I'd take a guess it's been used in a woods quite a bit and around some rocky ground. Thumb isn't bucket pin mounted but still better than mechanical. Is the roof in one piece? Do any of the filters have hrs and dates marked on them? What's the engine and hyd bays look like under the hoods? Pretty sure it's got a yanmar engine which is excellent especially if hrs are correct . Make sure the main hyd pump is original, if not walk away quick. If possible run it for a good 1/2 HR or more and with a good flashlight look real hard for leaks. If you feel the hrs are correct that machine should have a lot of life left and I believe a well built unit. If I bought it I'd spend some time cleaning and generally fixing it up where I could , would do a lot for resale. I guess my .02 for what it's worth.
