Tractor Starts But Won't Move
/ Tractor Starts But Won't Move #1
marksb2620
Western Maine
Kubota B2620
Kubota B2620 HST
Warmed up for 45 minutes. Air temp 12 degrees.
Hydraulics functioning, backhoe , loader.
When stepping on the forward , reverse foot peddles , the tractor stalls quickly, but can recover when taking my foot off the peddle.
I researched this yesterday and thought I had found the answer as a seat safety switch issue.
I cannot se that there is such a switch on my tractor. Only two smallish buttons where the seat makes contact which don't seem to activate anything.
All levers are where they were when the tractor was used last, about 2 weeks ago.
Thank you!
/ Tractor Starts But Won't Move #2
Does it stall like the fuel to the engine is cut like when you turn the switch off, or does it strain like it's being asked to move an immoveable object? If it's the latter the brakes might be stuck on.
If I barely ask it to go forward or reverse, it might move about a foot before stalling / cutout /shuts off / no strain.
It does this when the shifter is in neutral too.
The engine starts and runs fine , throttles up nicely as always.
/ Tractor Starts But Won't Move #4
Kinda sounds like vacuum leak. :confused:
I don't know what a vacuum leak is as I'm a pretty good operator and I don't have any experience/knowledge in mechanical repair.
I guess that tomorrow I'll tent it up and put the space heater to it.
I'd like to resolve this before the next storm as the yard needs to be cleaned up from the last dribble of snow.
/ Tractor Starts But Won't Move #8
Not sure about your model, but you can usually follow wires to a seat switch.
If in fact the tractor isn’t stalling the engine under load because something is “stuck”, it sounds like it’s turning itself off because it “thinks” there’s an unsafe interlock condition.
What are the normal interlocks? When would safety interlocks normally cut out tractor?
Does you tractor have a seat occupied switch and a seat in vertical position switch? Do these work in conjunction with PTO and/or Neutral switch?
Is PTO on or off? Your symptoms sure sound like it thinks no one is in the seat and trying to drive (pressing hydro pedal).
Here’s a similar thread with a diagram. https://www.tractorbynet.com/forums/kubota-owning-operating/271245-2920-wont-start.html
/ Tractor Starts But Won't Move #9
The manual indicated that there is a seat safety switch. My L4060 will start with me out of the seat, but pushing the hst pedal will immediately stall the tractor.
Rather than type out the various tests I've attached the manual section for an hst
/ Tractor Starts But Won't Move #10
Yes, but....typically can you stand up and drive machine without it cutting out? If not, it’s probably your seat switch not recognizing that you’re sitting. (I.e. seat switch works in conjunction with pedal neutral switch)
....or do the seat switch test in the manual where you turn on the PTO.....but stay SITTING DOWN when you turn PTO on. If the tractor shuts off, again, it’s the seat switch not recognizing that you’re sitting.
/ Tractor Starts But Won't Move #12
Might be a frozen hydraulic line in the drive circuitry.
Heat might be a cure.
I was thinking this, but he says it cuts out instead of bogging and stalling, and other hydraulics work. Anything is possible.
I routinely get off the tractor while it is running. (parking brake on). Coby
I'll go through my manual again, I did not see this page . Rj
/ Tractor Starts But Won't Move #14
Yes, but...can you normally drive (move) tractor while standing up, not on the seat? With many tractors you can’t. The tractor knows this by monitoring seat switch and pedal switch. If seat switch has failed, and you press pedal, tractor thinks your not in seat and cuts out.
Do the seat switch test listed in the manual by operating PTO, but stay seated. If seat switch is bad and thinks your not seated, tractor will shut down.
This will prove it’s the seat switch.
This morning I put a tarp over the tractor and heated everything up for an hour or so.
The tractor is running and moving.
I'll call the dealership tomorrow to get an opinion as to what caused this situation and let the forum know as it might help someone .
Thank you all!
/ Tractor Starts But Won't Move #16
Did you check the hyd oil for water?...
/ Tractor Starts But Won't Move #19
My tractor will stall if I try to move it and the parking brake is not fully disengaged. Perhaps yours is not disengaged fully either? Maybe parking brake switch is out of adjustment if you have one on your Bota.
I called my Kubota dealer just now.
There is a seat switch !
It is a white plastic lever , a couple of inches long and about as thick as a pen.
I had seen it when trying to discover one, but obviously didn't recognize what it was.
I routinely fold the seat up, but during a past storm that area filled with snow .
Will spraying a small amount of WD40 eliminate the moisture.
Somehow I remember hearing that WD is not suggested in some circumstances.
Thanks for all of the thoughtful responses!
BUNDLE OF UNION STRUT COVERS (A60432)
BUNDLE OF UNION...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
UNUSED KJ K2512 - 25' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K2512 -...
