   / Your last generator Maintenance Run #4,961
Thanks for the links, now I have options to investigate.
It would be nice for the Honda to handle the essential loads in eco mode and get 30~40 hours out of 5 gallons of gasoline.
90cummins
   / Your last generator Maintenance Run #4,962
90cummins
I've not used any of the single phase Altistart units, I'll have a read of some datasheets this evening and report back on how well they might work with your fan motor and generator. I just finished commissioning a 3 phase Altistart for the 30hp motor on the wood splitter I'm building.
   / Your last generator Maintenance Run #4,963
Good stuff TM :thumbsup:.
IIRC, in/around that time you also got that minor carb problem resolved too.
Rgds, D.
Yep it was not starting well. Had to pull the recoil starter and then fire the electric starter. Seafoam seems to have fixed that. They were predicting ice followed by 6 inches of snow here overnight Monday into Tuesday so wanted to be ready. Since I was ready we got no ice and about an inch of snow. I woke up early to plow the drive. No need to do so. Say around with a cup of coffee and enjoyed the quiet.
EDIT: Also adjusted the set screw for how rich the fuel mixture is. Runs smooth with no choke now too. I suspect I'll have to readjust it come summer.
   / Your last generator Maintenance Run #4,964
I had a read through the data sheets on the Altistart 01: Seems to be same operation for both single and 3 phase motors. Given your application (generator power and starting a fan) I wouldn't enable the BOOST function.
Looking forward to hearing how this 120v addition turns out for 90.
Rgds, D.
Another one for Team Seafoam :thumbsup:
Won't fix broken parts, or totally plugged jets, but is a nice labour-saver for the rest.....
Rgds, D.
   / Your last generator Maintenance Run #4,967
I dosed my little Honda 1000 and decided to let it work...
Hoping for Miracle
   / Your last generator Maintenance Run #4,968
Power went out at 9:15 pm as wind picked up and restored just as I was leaving the house at 3:30 am.
Gas water heater keeps working power or no power... so not much to complain but generator at ready had it remained off when home for lunch to keep refrigeration.
   / Your last generator Maintenance Run #4,969
dont you love having the option of having power at least. i guess they shut power off on purpose? due to the winds?
   / Your last generator Maintenance Run #4,970
Not this time... the wind toppled trees and limbs...
Above ground distribution is vulnerable... especially on 1920 utility poles...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
Kubota BX2230D (A47384)
Kubota BX2230D...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
