Good morning!!!!
   / Good morning!!!! #123,021
I feel exactly the same about Abbot's Green King, Watney Red Barrel, Newcastle Nut Brown Ale, and Whitbread Pale Ale, four all time favorite English beers that are no more. But I didn't start on them quite as young as you started on your cookies, Doug!:laughing:
Funny thing is, there are/was three varieties and they still make the other 2 but just not a fan of them. (Super Wine and Vanilla Wine)
Fancy stopping making your favourite Ales RNG ... What a nerve!
   / Good morning!!!! #123,022
About the vaccine. I've read that the first 3 vaccines take 2 doses per person. They think it will take 30 days from the first shot for your body to get to peak immunity. Hopefully however they decide to give the shots they won't expose people to infection. I heard on the radio today 35 percent of people in the U.S. are thinking about not getting the vaccine which will make herd immunity a close thing. Even after you get the shots it may be possible to get infected and also to spread it to other people. Nothing is simple.
Chris
Apparently not going to be compulsory to vaccinate in Aussie. I am of 2 minds at the moment... Only 1 known case here caught from a traveller in quaranteen. Now isolated. (NSW)
Life is normal in Queensland.
   / Good morning!!!! #123,023
Phil, those cookies look wonderful, my favorites too.
Yes, my landlord left with a smile on her face.
She isn't used to a tenant like me...and she left me a nice amaryllis plant which I promptly planted and put on a sunny windowsill.
and if you are wondering what to do with your big Christmas bonus, well....:
https://directedmachines.com/?gclid=EAIaIQobChMI9P2Zha637QIVhzEMCh192gXfEAEYASAAEgIZ4vD_BwE
Many have wished to put solar panels on top of an electric golf cart, but the amount of power from such a small solar array is miniscule compared to the amount needed to use the cart regularly. They could work fine for a trickle charger....maybe.
   / Good morning!!!! #123,024
After giving it much thought, I have decided my favorite wood to burn, is the kind that someone else has cut, split, dried, and stacked. :shocked:
:thumbsup:
   / Good morning!!!! #123,025
So there is really not much sense in getting the shots if they don't work.
Well they haven't said exactly how the different vaccines work but if it keeps you from having bad symptoms or getting long covid that would be worth something. And of course if it keeps people out of the hospital I'm sure the health care people would be grateful.
Chris
   / Good morning!!!! #123,026
Just getting in from the first cleaning. We have at least 6 inches of heavy wet slop! The ground is still not frozen so the snow blower is useless. Just digs into the ground. I used the bucket with it curled up some. Good enough for a first pass. Still coming down at a good clip. Hopefully will be better in the morning.
   / Good morning!!!! #123,027
:thumbsup:
I can sure understand that. It seems that Oak is the most popular, but I had very good luck with Mesquite once I learned that it gets hotter and you have to not use so much at a time. In our first house with a fireplace, I burned mortar out from between the fire bricks and made a job for myself, re-caulking the fireplace.
   / Good morning!!!! #123,028
Our favourite wood for burning is Ironbark as it burns very hot. However, we have no fireplace as it is not required where we live. We use a reverse cycle air-con if it gets down to about 60 deg F. That is chilly here.
   / Good morning!!!! #123,029
33F and cloudy @ 18:30.
Was raining when I left for the Rodeo Roundup, turned into snow about halfway to first stop.
More tile, tools, and turlet acquired. Only thing I brought in though when I got back was the grout ... didn't want it freezing.
Great service at all three places ... :thumbsup:
Managed to snag three chili dogs for dinner from Skyline Chili on the way to the second stop.
Woman pulled in just about the time I turned the key and shut the van off.
Just before I left I looked out the kitchen window and saw a couple of does ... were they at the new deer feeder ?
Noooo ... they were browsing the ground ... under the squirrel feeder ... :laughing:
Ya gotta love it.
   / Good morning!!!! #123,030
Son’s bathroom toilet been plugged for a few days, so I found the toilet roto rooter thingy, and got it unplugged. water valve wasn’t turned on all the way, so turned it on some more and it started leaking real bad. Had to turn off house water again, and when I turned it off (another gate valve) it also started leaking bad around the stem. Got the toilet shutoff changed to a ball valve type. I picked up several a few weeks ago after I had to change one under a sink.
Decided to change the toilet shutoff valve in powder room, as I need to pull that toilet soon to do some work. After changing that one, have a small drip behind the compression fitting to the 1/2” pipe. Also forgot to drain the cold line first, and when I pulled the old one off, all the cold water from higher pipes came out.
Started to change out the geo flow center, and decided since it takes 4 gallons of water, I should put some more antifreeze ( propylene glycol) in, so ran to TSC for a gallon. Then ran to Lowe’s to get more electrical connectors since the new one’s boxes are different. Decided to stop work for the night.
Fired up pellet stove for first time this season. Has that smell after sitting so long.
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
