Extended WIFI from House to Barn to control Tractor Block Heater from Phone
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #1
Puddlewalker
Loveland, CO
2017 Massey Ferguson GC1710
My barn is about 50 yards away from my Router in the house and couldn't access the internet.
1. I added the NetGear PowerLine access adapters.
Hooked one adapter to an outlet close to my router in the house.
Added the other adapter to an outlet in the Barn. Magic - I have internet in the Barn.
2. Plugged in the ACENX Outdoor Smart Plug in an outlet next to my Tractor.
3. Downloaded the "SMART LIFE" app from "Google play" to my Phone.
4. Followed the ACENX Smart Plug Outlet instructions how to "Pair" to my Phone.
5. From my phone I set the "Smart Life" App and program to shut power off to the outlet - after two hours.
Equipment purchased:
1. NETGEAR PowerLINE 1000 Mbps WiFi, 802.11ac, 1 Gigabit Port - Essentials Edition (PLW1010-100NAS)
Amazon.com: NETGEAR PowerLINE 1 Mbps WiFi, 82.11ac, 1 Gigabit Port - Essentials Edition (PLW1:)-1NAS): Computers & Accessories
2. Acenx Outdoor Smart Plug Outlet Waterproof,Smartlife WiFi Outlets Timer
Acenx Outdoor Smart Plug Outlet Waterproof, Smartlife WiFi Outlets Timer Works with Alexa Google Home, Smart Christmas Light Timer for Light Strip Projectors, Schedule&Timer by App, 2.4Ghz WiFi Only: Amazon.com: Industrial & Scientific
Total Cost = $114.00
Enjoy!
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #2
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #3
Nice setup Puddlewalker.
I have the same situation as you with the shop a bit too far from home.
I just used a couple TP Link Powerline adapters and a smart switch for enabling/disabling an homemade alarm system. This also allowed me to have CCTV there.
These powerline setups are awesome and saved me lots of trouble by not having to run an ethernet cable from my house to the shop.
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #4
Thanks for posting... always interesting to see solutions that work.
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #6
Not to steal this thread, but WiFi related, I have a new Ring camera, I want to put it on the garage end outside of my house. When I get it into the garage (80’ from my router) it stops working. The camera needs to be mounted about 20 more feet away from where it stops working. Is there an extender I can plug into my AC outlet by the router and another into an outlet in the garage that will help? Thanks!
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #7
I'm getting ready to build a new 1000 sqft shop with a 250 sqft office that'll be 200' from the house (plans currently at permit stage). I'll be trenching for a hardwire connection to my main router.. WiFi is possible but would require some higher-end equipment which would succumb to the weather in my area. Plus, it's too dang slow! Trying to do virtual meetings with WiFi is like watching old Max Headroom videos. (points if you get that reference).
But if all you want to do is operate consumer switches.. it works.
If the MT125 ever shows up, the BH is gunna be busy :)
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #8
not cheap by any means, but my shop was 300 feet from my wifi router. i had a hard wired cat5 cable run years ago, but it finally gave up the ghost. it was troublesome from day 1 so i just descided to abandon the idea of a hard wire and went with a radiolabe wifi extender Extend ANY WiFi System to Shop, garage, barn - Connect kit | RadioLabs
i have flawless wifi reception in shop now. i need it to control my computer controlled plasma table and to use the shop computer. it also finally allows me to make and receive cell phone calls deep within my shop after i enabled wifi calling feature on phone. i used to have to walk out of shop to talk on phone...no longer do.
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #9
See the OP post #1
   / Extended WIFI from House to Barn to control Tractor Block Heater from Phone #10
Not to steal this thread, but WiFi related, I have a new Ring camera, I want to put it on the garage end outside of my house. When I get it into the garage (80 from my router) it stops working. The camera needs to be mounted about 20 more feet away from where it stops working. Is there an extender I can plug into my AC outlet by the router and another into an outlet in the garage that will help? Thanks!
Amazon.com: WAVLINK AC12 High Power Outdoor Weatherproof WiFi Range Extender/Wireless Access Point/Router with Passive POE, Dual Band 2.4GHz 3Mbps+5.8 GHz 867Mbps, 4x7dBi Detachable Omni Directional Antenna: Electronics
Mount this outdoors, you can use it as a wifi repeater, or use a high quality cat7 or cat8 cable and plug it into your current router (range extender). ATT router on north wall of house, wavlink outside on south wall. Cell phone in same room as ATT router will connect to outside router because of it's increased signal strength. Signal passing thru 3 wooden walls.
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
16FT box truck (A53424)
16FT box truck...
