Good morning!!!!
   / Good morning!!!! #121,411
36 here this morning headed for 65. A bit of morning fog as well.
Went to mount the post hole digger yesterday and the driveline was stuck. Turns out it was bent. Pulled it apart with a chain hoist by anchoring the other end to the floor with the loader. Was able to put in the press and straighten both the inner and outer sections and shortened them as well as there was way more overlap than required. I still have almost 12” fully extended. Coupled with having to get some more lumber, yesterday’s project will get finished today.
Dog decided she wanted to go out around 2am, had a hard time going back to sleep after letting her out. Turns out browsing for election news did the trick.
   / Good morning!!!! #121,412
Cloth face coverings and surgical masks do not require a seal to work, so beards and other facial hair should not impact their effectiveness as long as the face covering is worn properly. The coronavirus is spread through respiratory droplets, which originate from a person's respiratory system
Is Your Beard Putting You At Risk For The Coronavirus? | The Manual
ahhh, good. No shaving this morning. :thumbsup:
Unless you are a health care worker. They still recommend they shave. " . . .But for civilians wearing face coverings in public, and who are not exposed to COVID-19 patients,"
I just ordered some metal nose bridge clips that are sticky on one side to close the gap by the nose so my glasses don't fog. The no fog works unless the glasses get moisture from a mist or fog, then they get blurry. On a dry day the no-fog works OK. Like RNG says - if glasses fog there is a major leak.
(RNG, my wife says that I will take the fish outside and use the EGO blower to "dust" it :D)
52˚F heading to the 80's. Garden day and getting an Amish server hutch delivered to put behind my Craig's list antique solid oak table I bought several years ago.
   / Good morning!!!! #121,413
I've had a lot of cramp problems and after poo-pooing the idea for a long time I finally tried the mustard thing that has been talked about before and it works like a charm for me. When I first started I had the Grandkids snag me a few of the packets at the burger joint and after seeing how well it worked my wife found some on Amazon and I keep a small bowl on my night stand. Worth a try and yess I tried the Dr. way first with no help at all. Just the plain old yellow Kraft mustard.
Mustard works, I’ve been using it and pickle juice for years, one works as well as the other for me and it’s near instantaneous.
   / Good morning!!!! #121,414
Here is my morning greeter. He beds down right outside my back pasture.
   / Good morning!!!! #121,416
42 early, 72 later. Very foggy early but burning off rapidly, better than yesterday’s big frost.
Went to doc yesterday to check my arm, cleared to go without bandage during the day, still have to use it at night for a few days.
Gotta clean up ahead of the cleaning ladies today. LOL
Think I might take the deck off the tractor, remove the blades and sharpen them, lube everything and have ready come March.
Breakfast, Perry Mason, then get to work.
   / Good morning!!!! #121,417
BEF.
Our deepest condolences...special thoughts prayer to your family.
   / Good morning!!!! #121,419
Three stray kitties showed up in my front yard Monday evening. It was barely light enough for my phone-cam to grab a pic. They must be after the fallen bird seed from feeders just above. If anyone would care to adopt them, let me know. I'll watch for them again. :shocked:
   / Good morning!!!! #121,420
For Eric;
What is La Paz and Sucre .. Alex.
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
Kubota B2301 (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 KAWASAKI MULE 3010 UTV (A58375)
2008 KAWASAKI MULE...
UNUSED JCT DUSTLESS BLASTER (A58376)
UNUSED JCT...
