Snow Baldwin filters
/ Baldwin filters #1
muzbomb
Canada, Alberta
2016 Kioti 2610HST
Hey guys just wondering if anyone has used any Baldwin engine, fuel, HST and hydraulic filters for there CK2610HST?? I have been doing some searching and cross referencing to find the correct Baldwin’s. I would like to use Baldwin filters just for convenience wise as the local kioti dealer is a good hour drive one way.
/ Baldwin filters #2
Yes, Baldwin filters are of sufficient quality that you can use them as OEM replacement filters. Just make sure of your cross reference. I have used Baldwin several times, and they do work very well.
/ Baldwin filters
Ok yes I have been looking at researching Baldwin filters sure to seem to have a good name and quality behind them. It is just the hard part to cross reference and make sure getting the right filters is the hard part lol.
/ Baldwin filters
I have found this out so far with some searching not sure if correct numbers or not yet trying to confirm?? Attached is a pic of my factory filter numbers for my 2016 2610HST.
Hyd filter BT8488
HST filter BT26010
Oil filter ???
Fuel filter B1404 it lists about 15 more Baldwin’s too.
/ Baldwin filters
These are factory numbers from what I can tell
Oil filter E6200-32113
HYDRAULIC filter 2185-38031
Air filter T2198-11071
HST HYDRAULIC filter T2195-38031
FUEL filter T4682-43172
/ Baldwin filters
Nobody knows the Baldwin numbers???
/ Baldwin filters #7
It seems like a lot of effort/time on your part looking for the Baldwin filter numbers.Why not buy filters from your local Kioti dealer?
/ Baldwin filters
Well as i said in first message the dealer is a good 1 hour drive one way so would like to get Baldwin filters cause I can get them in town a 10min drive.
/ Baldwin filters #9
It’s pretty simple. Use Baldwin cross reference info. If Baldwin does not provide a cross reference for your tractor, do not buy Baldwin filters for it.
/ Baldwin filters #10
You can also get Wix filters too. They are as good as the Baldwin. And they supply alot of the OEM filters to tractor manufacturers, and also handle US military orders for filters. Also all NAPA store filters are Wix, but NAPA use their own filter codes.
Wix cross reference filters by equipment type/engines at this location:
WIX Filters - Products Catalog Home
I typically use Kioti OEM only, but this summer my Dealer was out of Kioti filters. All of them were sold and no replacements from Kioti. So I used a Wix oil filter and it worked great.
/ Baldwin filters #11
My Kioti dealer is also about 1 hr. drive from my home.When I am over in his neck of the woods I buy 3-4 filters to stock up.Saves time and gas $$
/ Baldwin filters
Well with some more work and google searches manage to find all filters i need in a Baldwin filter for my 2016 CK2610HST
Fuel -T4682-43172 =BF7838
Oil - E6201-32443 =B173S
Hydraulic - T2185-38031 =BT8488
HST - T5855-46531 =BT305
Air filter - E7230-11081 =RS3988
/ Baldwin filters #13
Muzbomb, those Balwin filters are good for the entire CK series of Kioti tractors
/ Baldwin filters
So not sure what you mean are you saying they are not good for my tractor or just that they are good for all CK tractors?
/ Baldwin filters #15
All filters we used on the farm were either OEM or Baldwin.
/ Baldwin filters #16
All engines in the Kioti CK series use the same oil filters, fuel filters and hydraulic filters. Therefore, the cross referenced Baldwin filters also apply to all tractors in the CK series
/ Baldwin filters
Yes we use Baldwin filters all the time on our work equipment with Mobil oils. We do oil sampling and we are getting 3000 hrs on a lot of our oils before company policy to change oils at 3000hrs regardless if the sample comes back good. I have cut a few Baldwin filters open over time at work and they are top quality filters from what I have seen.
/ Baldwin filters #18
I'm using the Baldwin on my CK2610H. Got from Greene's on eBay, search for "KIOTI tractor FILTER E6201-32443 CROSSED to a BALDWIN USA MADE 4pack" for about $39.
They work well.
/ Baldwin filters
That is for all filters and air filter. Also this is in Canadian play money lol
/ Baldwin filters #20
Thats awesome, great work!
A quick price search doesn't show saving much over OEM (10% maybe?) but might be able to dig a little deeper for better pricing.
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
karcher pressure washer (A61567)
karcher pressure...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A61568)
2018 Chevrolet...
Bomag BW172 PDB-2 Compactor (A61166)
Bomag BW172 PDB-2...
Genie S60 Boom Lift (A64047)
Genie S60 Boom...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
