Please help! I can't really believe this happened!
   / Please help! I can't really believe this happened! #1
CntryBoy
JD 4320,7420,3320
Hello all. I'm new to this forum. I stumbled across this group while researching vaporization temps and characteristics of diesel burn rates. A recent acquaintance of mine was involved in a terrible accident last week in which he was badly burned. He, like many other folks in Louisiana were cleaning up after the recent storm. This gentleman used diesel, straight from the bulk tank he uses for his JD tractor. He put diesel into an open topped 5 gallon bucket and prepared to do some brush pile burning. He trickled some diesel onto the pile, he then placed the can safely out of the way, leaned over with a striker(plastic one that emits a small flame)and lit the diesel that was on some leaves. It exploded! Both of his legs were badly burned, his R arm and hand were terribly burned. He was and still is being treated at a local burn unit. This man is like most of us... Very much a farm boy, very capable, very much a common sense type, had done this hundreds of times, etc. No there was nothing else but diesel in the can. No, there was nothing else on the pile besides branches and leaves that had been raked and piled earlier that day. No there was no chance of anything else in the bucket. What I'm hoping for are concerned thoughts/opinions on what happened and how to keep this from happening to someone else. We have all done this countless times before. Could the diesel have vaporized due to the hot, humid 92% ,heat index day of 105 degrees so common in Louisiana? If so, what are the ideal parameters for such a situation? Thanks in advance for help with this very perplexing situation. Please do not say "There's no way..." I am not asking for insults, or directions on the proper way to use diesel, or the proper way to burn a brush pile. What I am looking for are good, scientific based ideas on why the diesel "exploded"? I know we all think this won't happen to us but it happened to him while doing what I have done many times. Thanks again for your help!
   / Please help! I can't really believe this happened! #2
Maybe there was an unseen container, can, etc... in the pile.
   / Please help! I can't really believe this happened! #3
Welcome to TBN.
Wishing speedy recovery to gentleman.
"It exploded!"
Maybe diesel was mix with strong additive like non gel etc.
   / Please help! I can't really believe this happened! #4
Sounds like you already know what the temp has to be for Diesel to explode - those numbers do not change unless another chemical / element enters in, had the fuel been treated? If not had the vegetation been treated with some chemical? Methane / compost - You said the pile was wet, wet "hay" placed in a dry hot barn (compressed area works) ignites add fuel to it, it explodes - regardless wishing him a good recovery - sounds like he was doing the right thing, cleaning up after a storm sad to hear he got hurt.....
   / Please help! I can't really believe this happened! #5
From
https://southeastpetro.com/wp-content/uploads/2015/12/Diesel-FlashPoint.pdf
Flash Point Properties - At elevated temperatures, diesel fuel will begin to vaporize and become ignitable with an open flame. The lowest temperature at which the vapor will ignite is the fuel's flash point. Diesel fuel #2 as specified by ASTM D975 has a minimum flash point of 125.6 F. For diesel fuel #1, the minimum flash point is 100 F. (Winter blends of #1 and #2 are allowed to be 100 F minimum as well). If the flash point falls below these values, the fuel becomes potentially unsafe to handle.
If the fuel was in the sun on a 92 degree day, it could be over 100 degrees.
Bruce
   / Please help! I can't really believe this happened! #6
Hope he recovers quickly.
I've never been able to ignite diesel with a match. Almost need a wick to get it going. Think there must have been some gasoline in the bottom of that diesel container when he put the diesel into it.
Diesel ignites just a bit better than lube oil, which is not flammable unless ignited by something else. Generally, this is the case for diesel, too.
Ralph
   / Please help! I can't really believe this happened! #8
As a kid my friends and I were always blowing stuff up. We found out fumes were worse than liquid. We had a great burn pile with a nearby concrete "bunker" we could dive into.
A steel pail of gasoline we threw on a burn pile...then we tried just a small amount of gas sloshed around then went to throw that on. It knocked us both flat.
So sorry about your friend and hope he heals ok. The best bet would be a long pole like 10ft, burning rag on end. Most times I trail off with gasoline or lighter fluid maybe 20-30ft, light end like a fuse.
   / Please help! I can't really believe this happened! #9
My way of starting burn piles is just to start up a pile of charcoal in one of those chimney starter things and then stick the burning coals under the pile on an old piece of metal. Never fails. I’ll do a second chimney’s worth if I’m in a hurry or it’s raining. Never fails to start brush or anything since it starts out as hot burning coals underneath the pile and anything over it drys out and eventually bursts into flames. I feed a little dry stuff to help it along Getting it started.
Hope your friend recovers fully.
   / Please help! I can't really believe this happened! #10
THIS HAS HAPPENED TO ME, BUT NOT AS BAD. THE TIME IT TAKES TO MOVE BACK THE PAIL OF FUEL AND THEN RETURN TO LITE THE PILE IS ENOUGH TIME FOR FUEL TO VAPORIZE A LOT ON A HOT DAY. IT'S AMAZING HOW MUCH A PILE OF BRUSH WILL HOLD THE FUMES IN. AND LIKE IT WAS SAID, FUMES ARE MUCH MORE EXPLOSIVE THAN THE LIQUID. I POUR FUEL ON THE PILE NOW, THEN POUR A LINE OF FUEL ON THE GROUND ABOUT 12 TO 15 FEET AWAY AND LITE THE END OF THE LINE AND LET IT WORK IT'S WAY TO THE PILE. EVEN THEN THE HEAT WHEN IT REACHES THE BRUSH IS INTENSE.
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
