Buying Advice L2501, L3301, L3901, L4701 gear shift questions.
   / L2501, L3301, L3901, L4701 gear shift questions. #1
BrokeFarmerJohn
Columbus Ohio
2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
I’m looking at a used 4x4 L3901 gear shift tractor with less than 100 hours on it.
My questions: how do you like the gear shift compact? Regret not getting HST?
I’m not familiar with Kubota gear shift tractors, is it like a normal gear shift or like a shuttle shift?
What would be a good deal on a L3901 gear tractor with turf tires and less than 100 hours be? (I prefer turf tires)
My background: I have extensive experience with older (20s-70s) gear shift tractors. And a HST compact loader tractor (2005).
Plans for tractor: Box blade/ rear blade work, if it’s cheap enough I’ll buy a loader for moving smaller round bales of hay and gravel when needed, my last compact I had pallet forks on it 98% of the time, I rarely do dirt work.
My last tractor was a 48hp 2005 JD 4320 with a cab and R4 tires. Will I be disappointed using a kubota L series? Since selling the compact I have been able to get most of my chores done with a Ford 960 tractor (40hp live PTO) which I like a lot but sold. Wanting to get back to a utility frame tractor with wide front and independent everything lol.
I know over old gear shift tractors the bota will be a big upgrade, over 1500lb lift on the 3pt will do what I need.
Kubota’s 1100lb capacity on the loader is a concern, many times handling hay or lifting I found myself saying I could use a bigger tractor than the 4320 with 400CX loader. A lot of times it was over kill. I sold the 4320 to get out of debt or I would have kept it. Now that I have money saved up I would like to buy a “cheaper to get on” tractor. Something cheaper on the wallet. This bota is in that range. Any Insight is appreciated.
I have also showed myself, although more work, I can live without a loader, my buddy has a 28XL mahindra if I desperately need a loader. I do miss a loader tractor though.
   / L2501, L3301, L3901, L4701 gear shift questions. #2
Not much has changed in gear vs HST except buyer preference for HST. Approximately 90% of new compact tractors are sold with HST transmissions and Loaders.
Many 'L' series clutch & gear tractors without Loaders are 2-WD "mowers" not 4-WD. Confirm through inspection that the used tractor you are considering has 4-WD.
Adding an aftermarket Loader is usually too expensive to be practical. Kubota USA web site shows $4,441 plus sales tax for factory L3901 SSQA Loader. It is usually cheaper to buy a new tractor with a Loader option than to add a Loader after purchase.
BUILD YOUR KUBOTA: https://apps.kubotausa.com/configurator/BuildMyKubota.aspx?pgId=1&bmId=1010&sId=125
AFTERMARKET LOADER SUPPLIERS: https://www.tractorbynet.com/forums...act-tractor-aftermarket-loader-suppliers.html
L3901 platform is pretty narrow. You will be happier with TPH mounted rear bale spear or TPH mounted pallet forks for loads over ~ 700 pounds, which position the load over the fixed rear axle.
Many 'L' series clutch & gear tractors without Loaders are 2-WD "mowers" not 4-WD. Confirm through inspection that the used tractor you are considering at has 4-WD.
FYI: I had to crop the pics together in order to post pictures here.
It shows all the signs of being 4wd. I haven’t looked at it yet but there is chance I’ll get it cheap enough that I could buy a loader from a dealer and still be better off vs buying new. I’ll just have to see. Being it has no loader, has turf tires and is a gear tractor, I would think that will slow a lot of buyers. If I do buy it, I’ll use 3pt until it’s paid off and I can buy a loader.
   / L2501, L3301, L3901, L4701 gear shift questions. #4
When you look at it see if it has the front suitcase bracket. You’ll need weight on the front for heavy 3pt lifts.
Looks like a negatory on front brackets or guard, also I see no rear remote and looks like it has the cheaper turnbuckles.
   / L2501, L3301, L3901, L4701 gear shift questions. #6
If you can find a shuttle shift that would be alright. Most of those options just had a regular gear shift and it wasn’t even a good one. It just has 4 gears with hi/low. It’s a terrible transmission IMO.
   / L2501, L3301, L3901, L4701 gear shift questions. #7
It’s the economy model Kubota. No bells or whistles. I had an L3400 and an L2501. Both tractors were geared and bulletproof.
Too bad your so far away, I have the bracket and 7) 55# suitcase weights piled up outside my shop.
   / L2501, L3301, L3901, L4701 gear shift questions. #8
It shows all the signs of being 4wd. I haven稚 looked at it yet but there is chance I値l get it cheap enough that I could buy a loader from a dealer and still be better off vs buying new. I値l just have to see. Being it has no loader, has turf tires and is a gear tractor, I would think that will slow a lot of buyers. If I do buy it, I値l use 3pt until it痴 paid off and I can buy a loader.
Seems to be 4wd, but that is definitely a syncro-shuttle shifter in the photo....nice fingertip forward/reverse shuttle. Excellent transmission; bulletproof and convenient. Turf tires are the more expensive tire/wheel option. You probably won't have any problem swapping them as they are premium....but I'd give them a try first. I like the way they work myself, and like the extra side-hill stability.
Several companies still make a three point dump&loader for that size tractor. They used to be more common. Should be able to find a good used one, as nobody uses them now that FELs are so popular. They aren't expensive. Here's a photo.
   / L2501, L3301, L3901, L4701 gear shift questions. #9
I just sold my old dirt scoop for $100.
I found that the L2501 is a regular gear transmission. The L3301, L3901 & L4701 is synchronized shuttle.
L2501 is 8 forward and 4 reverse gears.
L3301-L4701 is 8 forward and 8 reverse gears.
I saw a video of a geared L2501 and it was totally different lay out which got me looking into it deeper.
2018 Bobcat E26 Mini Excavator (A55787)
2018 Bobcat E26...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
