BackRoad
I'll add a bit related to weight. Standard guidance is to get as much weight as you can...but there are times when weight can be a detriment.
I have a 1960 Massey Ferguson 35...light, yet a big hearted pulling and brush hogging machine...fun to use...and I'll not sell it. And then I have my MX6000 ROPS with HST.
I consider the MF35 to be a lightweight, the MX a mid-weight, and the M series and above to be heavyweight.
Part of the reason I like the MX6000 is the ~60 HP in a slightly smaller/lighter frame than the full-sized Kubota M series.
I have 35 acres in Northern PA, with a 1/2 mile drive to maintain. I mow 8 acres of it with the MX and an 8' finish mower, simply because I like the way it looks! The goal is to maintain that section as smooth as possible and to keep it rut free.
Weight is your friend, but not if your goal is smooooooth.
With our wet clay in the spring, excessive weight can get one trenching towards China, rather than staying on top leaving minimal tracks.
It is a balancing act which the MX6000 achieves (for me at least) with appreciable and usable HP in the mid-size frame.
The loaded rears and 4 wheel drive keeps me going in the thick of it when using the grapple, loader, bush hog, land plane, plow and disc harrow, all are reasonably large capacity attachments, yet the tractor can still be nimble when needed.
Respectfully, I'm not doing production ground engagement like LouNY and many others or I may have gone bigger, and maybe not with HST...
But the MX is the RIGHT balance of HP and weight for my situation.
Oh yeah, and about the ROPS...I choose it over the cab. I can afford either, so it was not an economic decision.
It is my preference to fully experience the 9 months of open air freedom...with the wind, sun, clouds, even rain and simply accept the remaining 3 months of snow and cold...I have a good brrr suit!
I create a lot of seat time and the open station keeps me alive and in touch with the land, the weather and the world around me. I'm using the tractor because I want to, not because I have to.
While it's not for everyone, the MX6000/ROPS has been a perfect choice for me.
.../TJ
.../TJ
