How to clean up Styrofoam bits? Vacuum Technology Anyone?
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
So the poor little raccoons made a terrible mess in my barn. I had saved a bunch of 4x8 sheets of white styrofoam which is now spread in bits all over the barn. That and raccoon poop. Lots of it.
I wanted to park some industrial vacuum outside and just take the hose into the barn. Looking at all kinds of Industrial vacs, even cheap, Diesel powered mobile units, or a used self serve car wash style machine.
BUT, I assume the styrofoam is not going to settle in some cannister or 45 gallon drum style vac. I want it right in a disposable bag. Is there such a thing? That stuff is so light and worse, magnetic! Thought maybe a dust collection system, like for woodworking.
Any thoughts?
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #2
I have heard of success creating a pre-canister (5 gallon bucket and 2 - 2” 90 degree elbows) using cyclonic motion to leave the debris in the pre-canister and sucks the dust and finer particles through. Dump the pre-canister. YouTube has lots of plans and ideas.
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #3
Shop vac with a swimming pool vacuum hose. That's what I use for sanding jobs inside the house. The vac stays outside, the hose comes in through the nearest window or door.
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #4
FWIW...spraying with anti-static compound (available in spray cans at box stores/ wall mart etc) may help...
It's unfortunately spread too far and wide to treat them. Do they still make cloth feed bags? I have a big electric blower, I might be able to use for the styroafoam. Just tye rap the bag onto the outlet and put a piece of flex tubing on the inlet. The foam shouldn't hurt the impeller. The poop may (unfortuately) require a different technology.
I have a prettty good stainless shop vac, but I suspect that the bits will plug up the filter and not setttle in the canister. And, I would require WAY too many bags for several sheets of foam.
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #6
Just a thought here, I don't know it it would work...
Blow it outside on a rainy day with a leaf blower. Possibly, the rain will knock the magnetic problem out of it.??
If it does, then pick it up with the grass catcher on the mower.
I'm kind of **** about the slightest piece of FOD (Foreign Objects or Debris) here on the place. I'm thinking, I had better deal with it, still contained to the barn. Maybe some pictures will convey the true horror of the situation.
   / How to clean up Styrofoam bits? Vacuum Technology Anyone? #8
I have an EGO cordless blower with an extra low setting that I use for the garage and my shop, sheds,etc that would do the job if you had a big box or such to blow it in to.A regular leaf blower would just make the mess worse I think.
Maybe that's the ticket. A BIG cardboard box with an exhaust port/screen. Then burn the box.
Got me to thinking. Use my shop vac head on a cardboard box in place of the cannister. Maybe with the aid of a piece of plywood. For, I can see the joy of trying to remove styrofoam from the metal canister.
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
UNUSED FUTURE 48" LAND LEVELER (A54757)
UNUSED FUTURE 48"...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
Ford 655C 2WD Cab Backhoe (A55301)
Ford 655C 2WD Cab...
2009 Komatsu D51PX-22 Dozer (RIDE AND DRIVE) (A50775)
2009 Komatsu...
