4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,918
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
That's the part he isn't getting. Adding a foot to the width won't decrease his mowing time. It might even increase it because he may have to travel slower to get the same cut. I can almost mow an area faster with my 42" riders than I can with the 60" MMM because they take bumps and rough ground better and have a tighter turning radius. If his terrain is relatively lever and clear, his money may be better spent on a ZTR.. I can't use one due to my slopes.
I hear that all the time but I mow a lot of yards and I’ve never encountered one yet that I couldn’t mow on my ZTR. If you’re mowing it on your 42” rider it’s a 100 percent safe bet I can do it on my Grasshopper. I’ve got you beat bad on traction and center of gravity. And a 60” deck will never outperform a 72” based on hp limits alone. Not being able to fit is another set of problems. If the grass as light or the ground is rough you can’t go fast enough to use your HP and you’re wasting work. When the going gets tough and you’re going marginally faster with the 60” the same amount of work is still getting done. Or if it would make you feel better I could just overlap more and cut 60” with the 72” deck.
