Eye protection that doesn't insert under hearing protection cups
/ Eye protection that doesn't insert under hearing protection cups #1
Bullwinkle123
Southern VT
Kubota MX5400HST, Z724XKW-3-54
I recently acquired a zero turn mower, and it is the loudest piece of equipment I have ever operated. My traditional el-cheapo hearing protectors are not up to the task, so I've obtained some fancy new Peltor protectors.
However ... I also need protective eyewear, the mower throws up a lot of dust and debris. Short of wearing chemical goggles with an elastic band (big, unwieldy, maybe what I need though), is there something I can wear that won't insert under the ear cups of my hearing protectors? Because regular protective eyewear that wears like glasses definitely defeats some of the sound protection when the stems go over your ears and under the ear cup.
Looking for suggestion if you have had this particular problem.
I have seen ear cups that are notched for glasses frames,
Also there is this option;
ISOtunes Xtra | Bluetooth Hearing Protection Earbuds – ISOtunes.com
Thanks, but I'm going with the over ear protection, so I have a fat heavily insulated set of ear muffs that I will no doubt hate in the heat, but man are they quiet.
Now I just want eyewear that won't defeat their purpose.
Interestingly, most of the silicone or other foam ear inserts I looked at weren't anywhere close in noise reduction capabilities (according to the NRR or whatever it was rating) compared to the top shelf ear muffs. Taking it all with a grain of salt, since many vendors over-claim or use non-standards-based rating systems if they can get away with it.
I've used silicon ear inserts a lot in the past for other things, but was shooting for max coverage this time because this mower was really getting to me with the noise.
/ Eye protection that doesn't insert under hearing protection cups #4
There are some safety glasses, clear and tinted, that have very thin temples. Some are soft flexible plastic almost as thin as paper. They work pretty well under ear muff style protectors.
The last ones I bought were at Menards, but there were several to choose from and I would imagine they are available at HD and Lowes. I opened the packages to get a true feel for them before buying. Actually they were for my son, who uses them for the same purpose as you... mowing on a zero turn with large hearing protectors.
/ Eye protection that doesn't insert under hearing protection cups #5
Use expanding spray foam to fill in the gaps.
I have had the same problem,
Also, I was about to throw away a set of PELTOR behind the head, muffs, as they were not quiet anymore. Discovered the foam had gotten wet and just required some adjustment. Good as new. It doesn't take much to defeat hearing proetection.
/ Eye protection that doesn't insert under hearing protection cups #8
Looks like what my Dental Hygienist was wearing yesterday. Poor Girl!
/ Eye protection that doesn't insert under hearing protection cups #9
  • warren-mitchell-actor-with-bowler-hat-moustache-and-monocle-1972-shutterstock-editorial-1491763a.jpg
/ Eye protection that doesn't insert under hearing protection cups #10
Sorry, I troll a little bit. But have you tried just ear plugs? That's what I wear when mowing, it's works for me.
/ Eye protection that doesn't insert under hearing protection cups #11
I'm curious what you have for ear muffs, as most of what I've found have less noise reduction than ear plugs. When running chainsaw for any length of time I use both plugs and muffs, otherwise I will hear the darned thing echoing in my head all night.
You say that you will hate them in the heat and I agree. Yet you also would hate asking "what?" every time somebody speaks to you... and don't ask me how I know that.
/ Eye protection that doesn't insert under hearing protection cups #12
Ear plugs might be the only avenue for wearing glasses. Glasses with a strap might work not too bad too. Like when I wear goggles with muffs.
It takes me forever to install one ear plug effectively!
/ Eye protection that doesn't insert under hearing protection cups #13
You're working too hard at it, dude. Grab the top of your ear at the point, pull up on it while sticking the rolled up plug in, it goes right in. You straighten your outer ear canal when you pull your ear up.
/ Eye protection that doesn't insert under hearing protection cups #14
I will have to try that. I NEVER saw that on any instructions. More, that I shouldn't eat them.
/ Eye protection that doesn't insert under hearing protection cups #15
The first thing people are going to say is THAT'S TOO EXPENSIVE. The first thing I say is my eyes, head, and hearing is worth it.
Best protection I've ever worn. Comfortable built-in ear protection and I replaced the mesh with clear plexiglass because I work around date palms and the thorn could go through the mesh. I agree they're pricey BUT you but them one in your lifetime unlike always buying eye protection, helmets and ear protection time and time again.
/ Eye protection that doesn't insert under hearing protection cups #16
I don't remember if somebody told me that trick or I figured it out myself. But I dunno, maybe just my ears are whacked...it works for them, anyways. What do ear plugs taste like? :laughing:
/ Eye protection that doesn't insert under hearing protection cups #17
It depends. Before or after use?
/ Eye protection that doesn't insert under hearing protection cups #18
You might investigate motorcycle eyewear... there are versions that are designed to be worn with a helmet so as not to defeat the 'loud pipes saves lives' ear protection of the 'lid'.
Detachable 'arms' to a elasticised head-strap.
/ Eye protection that doesn't insert under hearing protection cups #19
Yabut, don't you need to be Vulcan to do that? I have no point on the top of my ears. :confused3:
/ Eye protection that doesn't insert under hearing protection cups #20
I read it someplace on an ear insert package... it was so long ago that I don't remember where. I get so accustomed to wearing them that I often don't bother taking them out when I stop for lunch... but still double up when running chainsaws
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
Husqvarna K750 Chainsaw (A65579)
Husqvarna K750...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
GUIDED FISHING TRIP FOR TWO - HISTORIC SOQUE RIVER (A64277)
GUIDED FISHING...
Plasma Cutter (A66408)
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
