Price Check L5460 Pricing and Input
/ L5460 Pricing and Input #1
RushB
Kubota L5460
Howdy All, new to this great site, what a helpful group of folks! I would like to introduce myself by asking for advice on a Grand L local to me. It was used in an apple orchard, 1600hrs, and has three rear remotes and no front remote. Looks like it needs tires, going to R4s.
My use scenario is road maintenance and heavy firewood production. Lifting IBC totes full of splits, a grapple load of timber, and load buckets full of granite gravel would be the heaviest loader applications.
Any input yall have would be appreciated! I cannot post links, but you can search Asheville craigslist for l5460 if you want to see the full details and lots of pictures.
asheville.craigslist dot org grd/d/hendersonville-kubota-l5460/7171055678.html
/ L5460 Pricing and Input #2
Grand L's are nice for sure;R4 tires/rims going to be expensive.What does it have now?Turfs?
/ L5460 Pricing and Input #3
Can't figure out the missing characters in the URL...
The medium loader will barely lift 1,900lbs (IBC tote 3/4 full of water). I'm guessing this has the big loader. IBC totes of wood are noticeably lighter than water, so that's a non-issue. It will lift a heaped bucket of gravel as well.
You'll need new wheels as well as tires if you are switching tire types. R4s are a compromise, but I've been happy with mine on my L4060.
Rear hydraulics suck on the grands & have leak down issues. Not the end of the world but annoying.
5,000-10,000 hours of life in a CUT. So 10-20% of the way through its expected lifespan. Not bad if cared for. But if it was used commercially by multiple operators it could be a bit more wear & tear than a single careful operator.
I'm happy with my L4060HSTC, especially the 2 speed HST+. Not as happy with the crappy rear hydraulics.
Thanks for the input. It’s got worn out R4s on it now.
It has the LA1055, I guess that is the medium loader? It should be ok for a 1500lb firewood tote I would guess?
It has R4s on it now I believe. I know tires are expensive but the price on the tractor is pretty good. I’ll attach the full link after this post.
Bummer about the rear hydraulics. I can’t imagine I will need three sets either, so that’s a double bummer.
Thanks a bunch for the great input!
/ L5460 Pricing and Input #7
That looks great, the LA 1055 should be good for a ton. Kubota used to number their FELs by Kilo capacity.
And you can probably lift twice as much on the rear.
The tires don't look "worn out" too me - lot's of life left in them.
Don't worry about the hydraulics.
Worry more about posting a CL ad for a good tractor here and it getting snapped out from under you :)
now where did I put my checkbook ????
/ L5460 Pricing and Input #8
Nope, the LA1055 is the big loader for the Grands. You will have plenty of capacity for your stated needs (even with only the medium LA805).
That bucket looked oddly clean without any scratches. Could just mean they only pulled stuff with the tractor, or the bucket could have been replaced for some reason. Bucket may be brighter than the rest of the machine. My bucket is way faded compared to my tractor, mostly because it gets left outside while the tractor lives inside (usually with pallet forks on). The rest of the paint looks to be in good shape.
It looks to have the upgraded air ride seat that's a $1k option. The 3 rear remotes are about $4k in options.
Probably a $37k tractor new. $19k knowing it needs new tires & is possibly 20% used up in general isn't bad.
/ L5460 Pricing and Input #9
Does the OP foresee needing a mid PTO?
If so, this tractor does not come with the internal gear unless it was selected as an option during the initial build. Bottom line... Likely to require splitting to install mid PTO internal gear. (Cab models come with the internal gear installed)
Probably should factor in the cost of a complete service (filters, fluids, etc...) as part of the overall cost of ownership. I'm not saying to deduct this from the asking price, but something one needs to consider when purchasing as it can be in the $500+ range.
I'd also check for any error codes that might be present given this has full emissions.
/ L5460 Pricing and Input #10
I've had turfs, r4s and r1's. For your application, I highly recommend r1s.
/ L5460 Pricing and Input #11
Just for a comp, I sold my hard worked 2004 Cabbed L4630 GST, LA853 loader, 2 rear remotes, 3200 hrs, really worn out tires [heavily cracked but not leaking] for $14K.
That L5460 seems like a good price.
/ L5460 Pricing and Input #12
An IBC tote cage holds about .38 of a cord. A cage's worth of green split hardwood could weigh 2000lbs or more. Plus ~100lbs for the cage and ~300lbs for the pallet forks. My Branson's loader is rated at 2200lbs and it's near it's limits with one of these. If I don't slide the forks fully in and leave it just a couple inches out, the loader will not be able to curl the load. The Branson is heavy for a tractor it's size and I have the rear tires filled with Rimguard. With a 550 lb box blade on the back for ballast I can really feel the weight of the full tote out there.
You may want the big loader if you'll be doing a lot of this.
/ L5460 Pricing and Input #13
The OP's "Lifting IBC totes full of splits, a grapple load of timber, and load buckets full of granite gravel" are all heavy loader loads. I thought R1s were not as suited for heavy loads as R4s?
/ L5460 Pricing and Input #14
FYI...
R1's: F-TIRE 9.5-16 R1 Gdyr Dura Torque 6stud Load Capacity: 1,390 lbs
R4's: F-TIRE 10-16.5 R4 IN Steel Bias AA Load Capacity: 3,500 lbs
Thanks for clearing that up, the loader looks plenty capable to me. No worries, if you get it before I look at it I won稚 be upset!
Thank you to everyone providing input! This is great insight, with great discussion!
I guess I will have to get the smaller 275 IBC totes, no worries about more trips.
Headed to check the tractor out now, I will report back with what I find!
Thanks again for the help!
/ L5460 Pricing and Input #17
This is the limit of the medium loader. You could guesstimate how full the 275 gallon IBC tote is & figure out how many gallons are in there times the weight if water to get a better idea. Experience tells me about 1700-1900lbs plus probably 200-300lbs for the forks themselves. But that's rather academic as you can no way fit that much wood into an IBC tote. To much space between the logs to come close. I have some IBC totes with firewood in them & they are way lighter.
And he's got the big loader that lifts 1,000 odd KG instead of the 805kg mine lifts. 805kg = 1,774lbs. As others have noted Kubota loader models equal their lift capacity in KG.
Grands bigger than the L4060 have a bigger front axle & can take the bigger loader. On my L4060 with the medium LA805 loader the weak point is obviously the hydraulics. Probably not obviously the front axle as Kubota doesn't let you spec the big loader on the machines with smaller front axles. The machine is rock solid stable at max lift with loaded rear tires & minimal rear ballast. I only tested once with low 3pt ballast & always run proper ballast. 20180701_185900.jpg
Grands bigger than the L4060 have a bigger front axle & can take the bigger loader. On my L4060 with the medium LA805 loader the weak point is obviously the hydraulics. Probably not obviously the front axle as Kubota doesn't let you spec the big loader on the machines with smaller front axles. The machine is rock solid stable at max lift with loaded rear tires & minimal rear ballast. I only tested once with low 3pt ballast & always run proper ballast.View attachment 665308
This is good news, because I bought the tractor today! Thanks for the detailed post!
Getting delivered in a few days. Picked up pallet forks as well.
Thanks again all!
/ L5460 Pricing and Input #19
Thanks again all!
Good on you, enjoy your new machine:thumbsup:
/ L5460 Pricing and Input #20
Congratulations RushB!
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
New/Unused Quick Attach Pallet Fork Frame (A61166)
New/Unused Quick...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
2018 Infiniti Q60 Coupe (A61569)
2018 Infiniti Q60...
