Good morning!!!!
   / Good morning!!!! #116,091
Awning did not come with 2 remotes?
My sausage is Bob Evans links. Mostly because that what they have at Sam’s Club.
Hmm, soon another grapple owner.
Nope, one remote is the deal, but I can get one for 19.95. LOL
I get my Swaggerty at Sams also, and Bob Evans is my second choice.
Maybe, maybe not on the grapple, at least I want think about it.
   / Good morning!!!! #116,092
   / Good morning!!!! #116,093
While drinking my Double Red Rooibos Tea I filled out the application and I'm in and have my watch ordered!
I filled out the application a few weeks ago, known history of Afib, heart procedure in the last year, I was turned down for the study.
   / Good morning!!!! #116,094
I buy Bob Evans because of package size. 24 last me 8 weeks. That’s about end of Best By date.
   / Good morning!!!! #116,095
Randy .. do you have a comparison of jaw "grip force" between hydraulic cylinders and electric actuators?
May not be an issue for you but I've had the experience, with both 55 HP and 100 HP tractors, of big logs or complete dead trees so heavy that I could lift .. but not curl. The grapple jaws held the load just fine. If not .. I'd have to cut them into shorter lengths.
   / Good morning!!!! #116,096
Good afternoon. It was 75° and sunny first thing this morning but, soon changed to dark skies and another 1" of rain this morning for total of 4" over two days. Looks like more rain tomorrow.
I was stuck in the shop most of the morning so I got back to working on one of my air compressors. Seems to be going around .. huh Kyle? The compressor would pump up to the 150 psi cutoff, shut down, and bleed air continuously from the compressor unloader valve .. that should just vent for a second or two to take pressure off the top of the piston. While looking into a replacement unloader valve I saw a couple of sites that suggested this symptom was actually from the tank check valve.
I disconnected the piping from compressor and from the unloader valve and shot some Fluid Film into the check valve and the reconnected the piping. I came back to it, about 30 minutes later and restarted the compressor. It pumped up to 150 psi, cut off, the unloader vented for about a long second and then reset. I hooked up my Radiator Genie and vented air until the compressor kicked on again and it all worked correctly. I'm not sure if the Fluid film in the check valve resolved the problem or if some of the FF got pushed up the line to the unloader .. but it works.
Have any of y'all looked at the Kardia Mobile EKG monitor? $89.
KardiaMobile EKG Monitor - Instant EKG on Your Phone | AliveCor – AliveCor, Inc.
Amazon.com: AliveCor KardiaMobile Personal EKG | FDA-Cleared | Detects AFib: Health & Personal Care
I had a short bout of PCV's, back in 2016, that showed up during my annual physical. I had no symptoms but .. went up and spent a day at the Austin Heart Hospital for an ablation procedure. My heart Doc suggested a Kardia monitor after I had the procedure. I check my BP (Omron 10 monitor) first thing every morning and do the EKG with the Kardia. All normal for over four years now.
Hope everyone has a great week.
Prayers to all.
   / Good morning!!!! #116,097
I’m not old enough. I get afib.
   / Good morning!!!! #116,098
I'm not 65 yet, nor do I have an I-phone. I guess they are going after the hoighty toighty old folks. :)
Rick, It looks like the unloader valve on my Speedaire is maybe a schrader valve. I could see where it could get a speck of something on it and not want to seal 100%.
I have some nice 1/2" airhose that a guy at work gave me when his project ended. Not sure I have the quick disconnects I need, but I want to come out of the air tank and put a T. One side would be the standard 3/8" couplers, the other side would have a valve and a 1/2" coupler for my impacts, or for trying to get large tractor tires to bead up.
At work, both compressors are plumbed with timers to drain the bottom of the tank every 5 minutes or so for a few seconds. At home, the speedaire's drain is an inch or 2 off the ground, with not much room for a hand. I might mount an old airgun to a short hose and tie it off up higher to make it easier to drain.
   / Good morning!!!! #116,099
Favorite sausage? I'm the only one here who eats it so ...
Breakfast sausage.
For red beans & rice or gumbo or with scrambled eggs.
   / Good morning!!!! #116,100
Good morning folks, thought I would join in.
Already 81 with a dew point of 67 high of 91 with a heat advisory until 8pm.
Boy the older I get the less my lungs can take heat and humidity.
Enjoy you day all.
Luther
How you doing Luther and pull up rocking chair joint right in. :)
Yep the 3 H's has a way making person go slow motion...stay low and stay cool next couple days.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
