Deere Dude
Elite Member
- Joined
- Feb 10, 2011
- Messages
- 4,014
- Tractor
- John Deere 3720
I use HF chain so I am good to go.
Here's an example of a chain snapping back. Incredible Accident: Chain Snaps and Smashes through Windshield, killing the driver! - YouTube
Yeah that痴 unfortunate that they yanked with so much force and speed, used such a long chain and didn稚 drape the chain.
Stupid is as stupid does....
you mean to the Morgue?..I use HF chain so I am good to go.
Also, a lower grade chain is less likely to have as much stored energy before plastic deformation and will more likely deform rather then snap.I was curious after reading some of the back and forth on here, and wondered if chain could snap back or does it fall dead to the ground when it breaks. I was surprised to find the video showing an extreme snap back, but I did find some interesting info I hadn't considered. Chain will fall dead to the ground if it breaks without stretching. It's the elastic stretching that makes cable, rope, or chain snap back. If you use proper sized chain and don't exceed it's WWL it should not snap back if it breaks (weak pin, hook, etc) since the links do not stretch under that WWL. Once that limit is exceeded, each link is stretched and if it breaks it can snap back similar to a rope.
