ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,442
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
Consider Newtons third law. For every action there is an equal and opposite reaction. Therefore if you have 35psi of air in your front tires, the maximum pressure per square inch applied to the asphalt is 35psi. Now that pressure is applied over many square inches. That is why the tire patch increases as you add weight to the loader. If you have a 3500# load on the front axle no square inch of the front tire will exceed 35psi.
What if half of the tire surface is air space (the space between the tread lugs)? Wouldn't the tread lugs be able to press into the ground with more than 35psi? (The exact amount would depend on the stiffness of the tire belting)
