locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #261
I bought a LockNLoad look alike. Works great. Bought a LockNLoad with extended snout to get it onto the zerk on a little nipple greaser. Needed a 2nd one for my other grease gun which leaked badly at times.
These don't leak. Easy to remove.
Ralph
   / locknlube cupler for a grease gun #262
This is my post from early in the thread:
I am real happy with my LockNLube Grease Coupler.
I put it on the lever action, removed the steel tube and used a hose.
View attachment 371813 View attachment 371814
You normally don't have a hose on a lever style, because it would require 3 hands to use it. This way I have more flexibility and only need two hands.
And now it has a 4 foot long hose on it:
The coupler is still working good after 6 years :thumbsup:
   / locknlube cupler for a grease gun #263
I have a few zerks too that are difficult for the LnL to access. I just took a 6-inch grease hose, attached a zerk to one end and a regular coupler to the other and I use it as an adapter. So for the dozens of zerks I have on equipment I take advantage of the ease of greasing with the LnL and for those TWO zerks that are problematic I use my little adapter. :)
Was just thinking of something like that might work.
With that said, I bought a LnL over a year ago and never got it on my grease gun yet.
   / locknlube cupler for a grease gun #264
I did the same thing. Took me a very long time for me to get around to installing mine. So, I can truthfully say: You're missing out. You need to get it installed!
   / locknlube cupler for a grease gun #265
ME TOO!!!
   / locknlube cupler for a grease gun #267
I bought a regular LnL, but found it was too large in diameter to fit into the Zerk fitting recesses on the tractor FEL. It is plenty long enough, but too big otherwise. Does the XL LnL have the same tip end diameter as the regular? It would have to be only slightly smaller to work. I may just try chucking it up in the lathe and turning it down a bit. Thanks
   / locknlube cupler for a grease gun #268
Greasing took on a whole new life for me.
Lucked onto a 12 volt Lincoln for measly $25.00 so went hog wild and added a LNL.
Now lubing is fun!
Clean, well almost, hands.
   / locknlube cupler for a grease gun #269
My complaint with the standard coupler is that sometimes the grease leaks out around the zerk instead of going thru it, even pressing as hard as I can on the hose/coupler. I guess the connection has to be square on.
Would not the LnL do the same thing?
   / locknlube cupler for a grease gun #270
It can but it seems to grab on much easier and tighter than a standard coupler.
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Miles,26,126 (A50323)
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
