   / Share Pics of People Hauling or Towing Something Wrong #12,811
Somewhat back on thread topic:
   / Share Pics of People Hauling or Towing Something Wrong #12,812
Those cracks don't really have to do with the jack even though they are lined up with it... it all has to do with the stress concentration at the end of the weld on the tongue, the cracks on both sides line up with the end of the welds... It sucks but if you have a welder not a big deal, it looks like it's been around the block for a while, it happens... At least he obviously had tongue weight so you still have a trailer and neighbor! trailer sway sucks and can get bad... I've literally been towing, couldn't move the load forward and bought tongue weight...
Hard to tell from the photo, but it looks like the crack isn't shiny. With the paint & other surface rust on there you'd need a much closer photo. A bit if rust on the crack surfaces indicates it's been there a while.
I don't loan out my gear except to a few very select people who are mechanically inclined & treat stuff right. Or it's cheap equipment I don't mind losing (lots of the Harbor Freight stuff I bought for a single use then sits on the shelf forever). My truck, tractor & trailer really don't get loaned out. But I will help friends & operate them myself.
   / Share Pics of People Hauling or Towing Something Wrong #12,813
I'm thinking metal fatigue over the years that opened up gradually and became more visible after the last haul. It doesn't look like anything sudden.
   / Share Pics of People Hauling or Towing Something Wrong #12,815
I just hope the driver had time and presence of mind enough to duck.
   / Share Pics of People Hauling or Towing Something Wrong #12,816
:rolleyes:
   / Share Pics of People Hauling or Towing Something Wrong #12,817
And back to the regular presentation of those in humanity to beware of.....
Broke a long standing rule of mine and loaned out a trailor and got this back. As expected the guy had no idea how he loaded so much for the crack to happen. It’s kind of in line with the jack.
View attachment 662373View attachment 662374
I replaced it with a much better hitch. Replaced the jack also. Safety chain attachment also changed out. This chain attachment sure beats the weld on bent pins that I have seen in use. Way better than actually welding the chains on, which I think will not pass a inspection.
   / Share Pics of People Hauling or Towing Something Wrong #12,818
Curious why you went with the side mount swing back when the center mount A frame is the same price.
I have to use side mounts on mine and had to add a second one so the tongue wouldn't twist.
   / Share Pics of People Hauling or Towing Something Wrong #12,819
You can open the truck tailgate is one potential reason.
   / Share Pics of People Hauling or Towing Something Wrong #12,820
Flip up and/or stow and don't have to crank it all the way up for clearance. I've replaced all of mine with side mounts. Only thing, I prefer the side mounted crank rather than the top mounted.
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
John Deere Gator (A53317)
John Deere Gator...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A56858)
2012 Freightliner...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
