Buying Advice First Tractor Recommendation for 40 Acres in NC
   / First Tractor Recommendation for 40 Acres in NC #21
When I have a DIY task one of my tractors can't handle and is something seldom done I just rent the equipment. More cost effective.
I bought too big and heavy first time around and since moved on to a lighter and more nimble model for daily tasks. Still heavy enough and HP to do the jobs.
   / First Tractor Recommendation for 40 Acres in NC #22
Many tractor's specs add up the steering hydraulic flow and the system flow. But on most modern tractors those are separate systems with separate pumps. You can't actually use them together for an implement. The Deere 5045D's flow that you can use with an implement is 10.9gpm. The rest is for the steering system.
You'll need to go to a fairly large, more farming oriented CUT to get 12 gpm.
The post pounder may work with less than 12 gpm, just slower.
The JD 5045E 4WD open cab we're looking at is 5,400 LB. Should we be considering something bigger? An alternative would be to lease something now, and then after getting a feel for what we're really doing we can buy something more appropriate.
Our first year will be spent putting up fencing and mowing while we wait for the barn and auxiliary buildings to get put up. Year two and on we expect our tractor use to be more like the following:
Weekly use - loader work for moving manure from pile near barn to compost area and turning compost. Maybe moving large bales, but typically we buy small square bales.
Monthly - Spreading cured compost and mowing rested pastures. Unloading pallet deliveries maybe? Usually the grain guys unload right into the barn.
Bi-annual - Spraying, fertilizing.
Annual - Gravel road maintenance and digging ditches to control water runoff.
I can't think of anything else. Lots of things we do right now at the current barn are done either on our own two feet or with a farm truck.
Other equipment we plant to get are an ATV or Gator to assist with chores and a zero turn for weekly mowing.
Based on that usage I think the 5045 is at the upper end of what we'd need out of a tractor, and we're considering it just because we're using the post pounder. I was thinking of buying new so I wouldn't have to deal with potential downtime of a used tractor, but leasing might be a good option for me starting off and be cheaper than buying a tractor and trading it in or selling it for something smaller and with a cab. At that point I'll have more free time to deal with fixing anything up as well. I'm not a mechanic, but I work on my own car. Working on hydraulics and diesel engines would be new to me.
This is a good point. For one-off or infrequent use it might be better to rent or contract out.
Putting up our fence would cost $120k and still a lot if we only wanted the posts put in :thumbdown:
Thanks for pointing that out. The dealer said "blah blah blah "17 gpm, she's got plenty, lets step into my office blah blah blah."
I read elsewhere of folks using an old tractor with 9 gpm flow at the rear with their Shaver HD-10 and still having acceptable results, so 10.9 gpm should be good.
   / First Tractor Recommendation for 40 Acres in NC #26
This is part of my 3 rail fence.
I like it. At one time I had about 18 horses. Down to 10. I found that they like it a lot better if they don't stay in the barn. Check the cost, but here my rolls of hay contain about 18 square bales. I do lose some in feeding. All is stored under cover. We still have to stack, unstack, and feed.
   / First Tractor Recommendation for 40 Acres in NC #27
Do not get hung up on Shavers hyd requirement number. All you are doing is extending a 1.5 inch or so diameter cylinder. Flow equals speed. 8 or 10 gpm will wear you out if you drive posts for more than a few hours.
Most respondents are sitting at a keyboard or holding a phone reading specs and would not know an HD10 from a sledgehammer. I have used both.
Hardly anyone is going to use a post driver at wide open throttle and that is where the hydraulic flow specs are measured. Weight and loader capability should be your top priorities.
   / First Tractor Recommendation for 40 Acres in NC #28
I'd use the auger, hire a couple of football players, and save my tractor from all that pounding.
Part of not doing that is to use the money we壇 spend on the labor for things we can稚 do ourselves like drill a well or build a barn.
The money you don't spend on the Shaver HD-10 will pay for the football players, and you will have lots left over for beverages.
   / First Tractor Recommendation for 40 Acres in NC #29
John Deere 5045E
2008 - 2017 5E Series
Model years
Utility tractor
Series next: John Deere 5055E
Manufacturer: John Deere
Factory: Pune, Maharashtra, India
Variants:
5045D: 2WD Economy
5045E: 4WD Mid-spec
John Deere 5045E Engine:
John Deere 2.9L 3-cyl diesel
John Deere 5045E Power:
Engine (gross): 45 hp [33.6 kW]
PTO (claimed): 37 hp [27.6 kW]
Capacity:
Fuel: 18 gal [68.1 L]
Hydraulic system: 10.3 gal [39.0 L]
Front axle: 4.8 qts [4.5 L]
Front hubs: 0.85 qts [0.8 L] (each)
3-Point Hitch:
Rear Type: 2
Control: position and top-link draft control
Rear lift (at 24"/610mm): 3,192 lbs [1447 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: mechanical
Rear RPM: 540
Dimensions
Weight (shipping): 5,070 lbs [2299 kg]
Wheelbase: 80.7 inches [204 cm]
Length: 137.8 inches [350 cm]
Width: 57.3 inches [145 cm] (axle flange)
Height (hood): 53.8 inches [136 cm]
Height (ROPS): 93.9 inches [238 cm]
75.7 inches [192 cm] (folded)
Clearance (front axle): 13.4 inches [34 cm]
Front axle: Flange
John Deere 5045E attachments:
front-end loader
Loader:
Loader type: John Deere 553
Height (to pin): 122 inches [309 cm]
Clearance, dumped bucket: 94 inches [238 cm]
Dump reach: 35 inches [88 cm]
Dump angle: 41
Reach at ground: 74 inches [187 cm]
Rollback at ground: 33
Breakout force (at pin): 5,378 lbs [2439 kg]
Breakout force (at 800mm): 3,604 lbs [1634 kg]
Lift to full height (at pin): 3,133 lbs [1421 kg]
Lift to full height (at 800mm): 1,956 lbs [887 kg]
Lift to 1.5m (at pin): 4,008 lbs [1818 kg]
Lift to 1.5m (at 800mm): 2,891 lbs [1311 kg]
Bucket width: 72 inches [182 cm]
Mechanical:
Chassis: 4x4 MFWD 4WD
Final drives: planetary
Differential lock: rear diff lock standard
Steering: hydrostatic power
Brakes: hydraulic wet disc
Cab: Folding 2-post ROPS
Hydraulics:
Type: open center
Capacity: 10.3 gal [39.0 L]
Pressure: 2828 psi [195.0 bar]
Rear valves: 1 or 2
Mid valves: 2
Pump flow: 11.4 gpm [43.1 lpm]
Total flow: 18.2 gpm [68.9 lpm]
Steering flow: 6.8 gpm [25.7 lpm]
Steering press.: 1958 psi [135.0 bar]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Page information:
Last update: October 24, 2015
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
VIDEO: YouTube
Looks like a good choice to me.
   / First Tractor Recommendation for 40 Acres in NC #30
John Deere 5045E
Model years
Utility tractor
Variants:
5045D: 2WD Economy
5045E: 4WD Mid-spec
Capacity:
3-Point Hitch:
Rear Type: 2
Clutch: mechanical
Rear RPM: 540
Dimensions
Front axle: Flange
front-end loader
Dump angle: 41
Mechanical:
Hydraulics:
Type: open center
Rear valves: 1 or 2
Mid valves: 2
Electrical:
Ground: negative
Charging amps: 40
Page information:
5045E VIDEOS: YouTube
Appears a good choice to me. Checks all your boxes. Will move 1,200+ pound large round hay bales safely.
With 45-horsepower gross you can operate a 72" Rotary Cutter in dry grass up to 30" long at full 72" swathe width.
New/Unused Electric Golf Cart (A57453)
New/Unused...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
