   / Harbor Freight Tools that don't suck #13,361
Thanks for your input but couldn't you do that with any item and see bad reviews?
   / Harbor Freight Tools that don't suck #13,362
Absolutely, and I'm critical of many reviews. The first thing I do is sort by lowest and then read them to make a decision, sometimes I feel the reviewers are idiots and disregard them. But in this case when you read the reviews, there's a common theme of this item not working well outside, and many saying it's too weak for longer distances. Sidewalks and driveways both fall into those categories. But I like working with string and string levels for jobs like yours, so my opinion is skewed too. :)
   / Harbor Freight Tools that don't suck #13,363
It'll work. That is not a challenge for the cut-off saws. Tractor Supply also has a cut-off that appears to be identical to the HF one.
That link does not go to TSC's chop saw. It does install a tracking cookie, however, and then takes you to TSC's home page.
When I put the original statement in, I did not include a link. I do not know where the link came from.
   / Harbor Freight Tools that don't suck #13,364
When I put the original statement in, I did not include a link. I do not know where the [Tractor Supply] link came from.
That link goes to 'www.pntrac .com' not Tractor Supply. It's some kind of magic that earns money from TSC when you click it and land on the TSC home page. All I found in the first few Google hits researching pntrac on Google, was an apparent competitor: Cashback Tracker Pro WordPress Plugin
I researched this kind of link a couple of years ago because a similar intermediary I encountered here on TBN was flagged by my ISP as 'dangerous, can't let you go there'. The intermediary must have somehow got on a blacklist. But going straight to TSC or whatever it was didn't encounter that block.
   / Harbor Freight Tools that don't suck #13,365
Sadly, TBN redirects a lot of links. See a lot of Amazon links end up Walmart or some other place. Ticks me off TBN does that. Wish they would fix it.
   / Harbor Freight Tools that don't suck #13,366
   / Harbor Freight Tools that don't suck #13,367
I bought one of those levels, and it's worked very well for me. It operates on the very simple principle of a plumb-bob. The light is suspended and gravity holds it. I, too, used one to level my barn floor and it worked great. I also used it to "snap" lines on my walls as I added tongue and groove. I have a much more expensive rotary laser level that I use outdoors, but for a quick job with minimum set up, the HF level is fine. The light is not real intense, so a darkened room or red glasses helps. And the "spread" is limited.
One caution, I understand that it can easily be damaged if it's moved without locking the mechanism. There's a little plastic sliding lever that locks and unlocks the pendulum. I make sure to lock it any time the level is not actually in use.
   / Harbor Freight Tools that don't suck #13,368
If you aren't paying for the product, you are the product. Every commercial website from Facebook to TBN needs to make money to survive & be worth the owners effort. If they are free they are either selling you something or selling adds to the eyeballs they can get to the site, possibly your browsing data. Such is the world we live in due to people not wanting to pay. It's not a new thing & has been going on since before TV or radio. Muhammed does a good job with TBN but needs adds & redirect trackers to pay the bills and make money. I begrudge him making a few bucks WAY less than Mark Zuckerberg.
   / Harbor Freight Tools that don't suck #13,369
Intend to agree. I usually look at 2-4 star reviews & give them more weight. Personally something I review needs to be absolutely outstanding to get a 5 star review. The middle reviews tend to have more thought behind them as to why the item was good or bad & what deficiencies there might be. 1 star reviews tend to be rants often related to misuse with little valid supporting info.
   / Harbor Freight Tools that don't suck #13,370
Interesting, I have seen where there have been links added for brands (such as Kubota), and I have seen you redirects added in the middle but I have never seen a link changed so that you end up someplace other than where the original poster intended.
Aaron Z
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
2006 Ford F-350 XL Superduty (A55272)
2006 Ford F-350 XL...
UNUSED MOWERKING PALLET FORKS (A58376)
UNUSED MOWERKING...
2016 Isuzu NPR 18ft. Box Truck (A56858)
2016 Isuzu NPR...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
UNUSED FUTURE 25MM MINI EXCAVATOR ATTACHMENT SET (A58376)
UNUSED FUTURE 25MM...
