sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,378
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Procrastinating again. 4' of trench in 3 hours, and Mr. Back is very unhappy with Mr. Shovel and with Baby Rock, Sister Rock, Brother Rock, Mrs. Rock, and especially Mr. Rock. Multiple Rock families, one of the Rocks for every two Clays, that love to stick to the shovel. But now I know which way the first bit of conduit is going, and it looks like it'll cross another one that I buried but not as deep. And it has to make a turn in not to far, so I'm reluctant to break out the backhoe. Ted, how did you avoid snapping that electrical line with your 'hoe? Could use some lessons in tip toeing with a back hoe...:confused3:
RNG why would you run in 2WD with a heavy load on the front?
I knew there was a wire there, so when digging, keep the bottom of the bucket level with the teeth, use the dipper stick to pull back without curling the bucket. You can shave a little off at a time, slow going, but as soon as I grabbed the wire, just backed off the pull ? popping it up. I am assuming that you do not want to pop up the other gas line, so just keep shaving a little at a time. You will feel and / or hear the bucket scrape the pipe.
I found an old waterline from a well we had that was inactive using the same procedure. I had an idea where it was at, but not really a specific location. I had to shave an area about 3 x 5 ft from about 2 ft deep down to almost 4 ft until I found it. Shaved the dirt right off without a scratch on the PVC pipe. Now I buy that cheap 1/2 inch vinyl marking tape and drop it in about six inches above whatever I am burying.
Hope this helps you out...
RNK
You make me chuckle. Back when building the house. I agreed to dig the gas line trenches for the plumber with my backhoe rather than having him bring his machine back. One of those line would go pretty close to where the already installed water line sat. Of course, I continued until I snagged it, separated it at the fitting. Not a problem, just go to HD, get a few CPVC fittings and all would be good.
So, there I am, in the plumbing aisle, bunch of fittings in hand and who walks up, my plumber. Seeings the fittings and of course asks what I’m building.
Never seen him there before or since. He did laugh, said not to worry his guy would fix next morning.
