Ford 1710 Rear Remote Valve
   / Ford 1710 Rear Remote Valve
I have a 1710 also what would it cost me for you to make another valve adapter?
I currently sell the kit for $350 shipped. That includes the adapters, hardware, and gaskets. That doesn't include the valve or the quick connect fittings, but I can add them if you don't want to buy on your own. If you want to discuss more, send me a PM.
   / Ford 1710 Rear Remote Valve #22
tedward4, Do you still make/offer the rear remote valve, I've got a ford 1720.
Paul
Paul
Paul, I'm working on designing an adapter for the 1720. The 1710 one won't fit the 1720. I don't have an ETA on the adapter yet though so you might have to keep bugging me to get working on it :)
   / Ford 1710 Rear Remote Valve #24
tedward4: Thank you for your quick response.I will check back with you later.
Paul
   / Ford 1710 Rear Remote Valve #25
Here's a quick look at the rear valve I added to my 1710. New Holland parts shows that the remote kit for this model is no longer available so I had to come up with a custom solution. I see a few places sell an adapter plate to tap into the three point lift hydraulics, but it's only an in/out port adapter. I really wanted a mounted valve to eliminate some hoses. The first picture on the left shows the stock port cover and the second shows the new valve setup. The valve setup is made up of two adapters and a Prince SVW sectional valve. I recently purchased a CNC machining center, so I was able to machine the adapters myself.
View attachment 439173 View attachment 439176 View attachment 439177 View attachment 439174 View attachment 439175
So did you complete one becuase I am in need and would totally buy
I only have the 1710 one available, but still working on the 1720 one. What year is your 1720?
   / Ford 1710 Rear Remote Valve #28
Do you have a kit for the 1720?
   / Ford 1710 Rear Remote Valve #29
I to would de interested in a remote kit for a 1720
66'' root grapple (A53421)
66'' root grapple...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
