Please Offer Your Ideas For a "Hand Anvil",,,
   / Please Offer Your Ideas For a "Hand Anvil",,, #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
The biggest "hammer" I have weighs 4 pounds,, the biggest sledge I have weighs 16 pounds.
There are times when neither of these are heavy enough,,
like someone just mentioned in another thread, use two hammers to disassemble a tie rod end.
As a backup hammer during striking, it is pretty difficult to have too much weight behind whatever is being struck.
Even flattening a piece of metal by using two hammers,, the bigger the hammer the better,,
So I am planning on making a giant hammer, that can also double as a small anvil,, which has a handle,,
A guy gave me the "worn out" swing hammer out of a giant recycling shredder, which will be the basis for my new tool,
The piece is 10" tall, 6" wide, 3.5" thick, and has a 3" hole through it.
Right now, the hammer weighs 40 pounds.
If my bandsaw will cut it, I hope to reshape it into a more useful shape, maybe something like I marked on the hammer in Magic Marker.
I will add a 1.5" solid bar as a handle, probably 48" long, I happen to have a length of DOM tube that is 3" OD, and 2" ID,,
I also have a piece of 2" OD, 1.5" ID DOM tube, so, I can make a pretty good fit of the handle,,
The last 24" of the handle will be knurled. The final weight after shaping and adding a handle should be 50-60 pounds.
So,, OK,,, what are your ideas,, before I start cutting,, and welding,,
How would you build the hand anvil??
   / Please Offer Your Ideas For a "Hand Anvil",,, #2
My first consideration would be...who is going to hold it in position.
My back hurts just thinking about holding it with the left hand while the right swings a hammer. :)
   / Please Offer Your Ideas For a "Hand Anvil",,, #3
Wrap the handle in something to reduce the shock transfer. There is a reason sledgehammers have hardwood handles.
   / Please Offer Your Ideas For a "Hand Anvil",,, #4
I’d recommend a different handle. A super heavy handle offers no benefit and makes it harder to manage. A wood or at least much lighter pipe handle would be better.
   / Please Offer Your Ideas For a "Hand Anvil",,, #5
I'm wondering about making the head "modular" so you could attach different length handles or bases/mounts to it. Maybe you could weld a large threaded male pipe nipple or female pipe coupling to the base, and screw your various attachments to that.
Thanks for the input,,, :thumbsup:
I like the handle ideas,, I guess I will reconsider the solid 1.5" bar for the handle,,
for the first attempt, I will probably use 1.5" OD,, 1"ID DOM tube for the handle,,
with that for the handle, if it is too rigid, I can cut it off and install a 1" solid bar as a handle, which would add some flexibility.
I doubt anything less than 1" solid bar would survive any use,, wood or fiberglass would break IMHO,,
Hopefully, tomorrow will be warm enough to try cutting the head,,
I have a 4x6 saw which uses low cost blades,, I will try that before using the 9X16 saw, which uses $$$ blades,,,
ONE other question,,, Should I drill a hole in the head,, kinda like a "Hardy Hole" on a regular anvil?
   / Please Offer Your Ideas For a "Hand Anvil",,, #8
If the bandsaw doesn’t do well, try a cutoff wheel on your angle grinder. I have always been successful using the angle grinder on thick steel (especially hardened steel).
   / Please Offer Your Ideas For a "Hand Anvil",,, #9
A cant hook handle would be a hefty choice if you wanted to try wood. Or you could craft your own wood handle with a draw knife.
I think you'll need blades with 2 tpi for something that thick. Maybe less?
   / Please Offer Your Ideas For a "Hand Anvil",,, #10
That's no challenge for a cold-cut saw, if you have one.
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
CATERPILLAR 315FL CR EXCAVATOR (A51242)
CATERPILLAR 315FL...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
Toro Mower (A50324)
Toro Mower (A50324)
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
