Mini excavator/skid steer vs backhoe.
   / Mini excavator/skid steer vs backhoe. #21
The excavator has killed all TLBs here, don't think I have seen one in commercial use since the late eighties. Suppose the same happens in the US to.
Not so much. The first midi/mini Ex I saw was in Korea in the late 80s. Other countries have been way ahead of us in that regard. Another one is excavators on 4 wheels. We rarely see those here.
Off topic Agvg, check out this thread concerning front mounted 3pt hitches. You have a lot to contribute to that subject.
https://www.tractorbynet.com/forums/attachments/421343-front-3-point-hitch-factory.html
   / Mini excavator/skid steer vs backhoe. #22
Some Townships still use the TLB's around here because they can be driven throughout the Twp for ditching/road repairs vs hauling.
Also can be used to load the trucks with gravel, anti skid, Etc.
   / Mini excavator/skid steer vs backhoe. #23
Yep. There are a lot of TLBs still used here too.
   / Mini excavator/skid steer vs backhoe. #24
The municipalities around here all own TLBs but rent mini exes for various small projects. Bigger jobs are contracted out.
Growing up the only wheeled excavators I ever saw were the Gradalls with telescoping boom for roadside ditch maintenance.
Now I see a lot of wheeled excavators. Mostly Cat and JD.
   / Mini excavator/skid steer vs backhoe. #25
The first I saw and tryed was a Takeuchi tb12 around 1985.
To be a little more off topic, any using a rotortilt as shown on the pictures? utzwr7mdsdztzd7r1vtd.jpg
   / Mini excavator/skid steer vs backhoe. #26
I've never saw one personally.
   / Mini excavator/skid steer vs backhoe. #28
I don't entirely agree. In fact I think I mostly disagree.
I've had a tractor + backhoe, and a while back traded the BH attachment for a mini-ex. I haven't once missed the BH, not even the slightest, ever. The mini has better reach, more power, significantly more maneuverability, and works with a bunch of other implements like mowers and mulchers. It's hands down better.
Now I agree that a real TLB would be better than tractor+BH, but I would still take a tractor + mini ex any day.
I think the argument is about what to get if you can only have one piece of equipment. Then I definitely agree it would be a TLB or a tractor+BH. But given the ability to get a second piece of equipment, I'd dump the BH or TLB in a second and get another mini.
I'm also probably one of the few people who doesn't like skid steers. They work great on a construction site, but otherwise I'm not a fan. Too easy to get stuck and/or trash the ground. I think a wheeled machine is much better.
   / Mini excavator/skid steer vs backhoe. #30
I've had a tractor + backhoe, and a while back traded the BH attachment for a mini-ex. I haven't once missed the BH, not even the slightest, ever. The mini has better reach, more power, significantly more maneuverability, and work with a bunch of other implements like mowers and mulchers. It's hands down better.
Not I agree that a real TLB would be better than tractor+BH, but I would still take a tractor + mini ex any day.
I think the argument is about what to get if you can only have one piece of equipment. Then I definitely agree it would be a TLB or a tractor+BH. But given the ability to get a second piece of equipment, I'd dump the BH or TLB is a second and another mini.
You can't disagree and then interject tractor + backhoe. We've all agreed that's at the bottom of the list.
If you've never owned a real TLB then it's hard to go with your preference of a tractor (with FEL I assume) and a mini.
Yes, the discussion is about only owning one. And again, if you've never been around a TLB it's hard to defend a mini.
I agree concerning Skid Steers. That's why I would always go with a CTL.
HAMM HD+120i SMOOTH DBL DRUM ROLLER (A52706)
HAMM HD+120i...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A55302)
2022 NEW HOLLAND...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2014 Ford Escape (A50324)
2014 Ford Escape...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
