Turf rims for Bison S670D
/ Turf rims for Bison S670D #1
Volvoman
While my Bison S670D currently has ag wheels & tires, the plan is to convert over to turf tires as soon as correct wheels can be located. Already have the tires for them, but finding the wheels by themselves are going to be the challenge. Rears tires are 13.6-16 tires on 12X16 wheels. Fronts are 6-14 tires on 5X14 wheels. Center pilot on both front and rear is 4 5/8? Bolt circle is 6X6? Casting a wide net for these, so asking here seems like a good place to make a request. Anyone here have a pair of either the front or rear wheels to spare?
I do have a set of 12-16 rear wheels from an Iseki, but the center pilot hole and bolt circle are not the same as used on the Bison. If the correct rear wheels cannot be found, has anyone fabricated a new ring with correct center hole and bolt circle, then welded it into the center portion of the original wheel disc, followed by reaming out the original rim center hole, then drilling the new lug bolt holes through the original by following the new holes pattern? Kind of a clumsy explanation I realize, but the idea is to make a new center disk and sandwich it over the old one, then welding in place.
Another variation would be to simply make an completely new flat center disc plate for the wheel, then cut out the old center and weld in the new one. This may well be the easier way and certainly stronger and not have a cobbled together appearance.
Any thoughts?
VVM
/ Turf rims for Bison S670D #2
I have a Bison with the 13.6 x 16 tires and 12 x 16 rims. One is rusted from tire being loaded with calcium. I've looked and looked for a replacement, but no where to be found. These look like the might work, but only 10" wide. may have to go with a thinner tire
/ Turf rims for Bison S670D #3
need 3 posts to add a link
/ Turf rims for Bison S670D #5
I needed new front 12" wheels for my Mitsu.
I used 12" trailer rims, knocked out the center and had a shop make me new centers and welded them on the stripped trailer rims.
While I was at it I had them do the centers in 5/16" stock so they are really HD.
Just so say, yes it is a 'can do' .
The machine shop charged me about $60. for the pair of 'fancy HD washers' !
/ Turf rims for Bison S670D #6
Valley Power has dealt in Satoh and Mitsubishi for many years. They do maintain a wrecking yard with lots of spares. Valley Power
Thanks everyone for your replies. Here’s an update on where I am on this. After considerable research, I came up with this so far: For the front wheels, I have ordered a set of Deere LVA13634 rims. According to online specifications, they are 5X14 rims size with 6X6” bolt circle and 4 5/8 center pilot hole. These specs are identical to the original Satoh Mitsubishi spec’d rims for the S670D. They aren’t here yet, but should be in a few days, so can verify then whether or not these are a going to fit properly.
As for the rear rims, Agwheelexrpess.com is a wheel supplier located in Iowa. They will provide a custom wheel using 11X16 rim with a flat disk center having 6X6” bolt circle and 4 5/8” center pilot hole. This is the correct wheel for the optional rear wide turf tires used on the BisonS670D. Price is $272 each. While I do have a set of similar 11X16 wheels here from an Iseki, the bolt circle and center hole is different. Removing the center disc, then fabricating a new flat disc for it probably would end up costing nearly the same. But, if the Iseki rims are sold to offset the cost of the new custom rims, my hunch is that going with new wheels will have a lower net cost. Short of having a buddy who can do the fabricating for a low price as a favor, another solution doesn’t seem to be out there....
Vvm
/ Turf rims for Bison S670D #8
Couple of questions. Will the 13.6 tires fit OK on the 11" wide rear rims? The link I provided above has the same rear wheels, bolt pattern and pilot hole but are 10" wide and only $118 each. Is an inch in width work over double the price?
thanks! I'm in the same boat as you, needing rims for my 16" rear tires
Good question, as I had considered dropping back to 10 width, too. Yesterday, I spoke with one of the knowledgeable folk at Agwheelexrpess about exactly this possibility. Here is what I learned from him: Eleven inch wide, 16 inch diameter rims are no longer manufactured, so that is not an option. The gentleman at AWE informed me that a twelve inch width is actually preferable to 11 width, which are slightly undersized for a 13.6-16 tire. And, 12 X 16 diameter rims are currently being manufactured, so all one needs to do is make up the center disc to whatever is needed by the tractor and weld it in. Done.
But, I have a set of 11X16 wheels that have the wrong bolt circle and center hole diameter. Should I re-drill them and enlarge the center pilot hole? I could, and might still do that, but that entails bringing them to a machine shop to get it done right. They would need to be chucked into a lathe to assure the new pilot hole is concentric, and the new bolt holes would need to be indexed to correctly fit the hub of the tractor. This takes some time (translation $$$), and the new center pilot hole would intersect with the old lug bolt holes, definitely not an ideal solution.
Another option I considered was purchasing a pair of 1/4 thick reinforcing rings having the correct bolt circle and center pilot and welding them onto the wheels I have. This would entail reaming/cutting out the existing center pilot hole due to its being undersized, then welding the reinforcing ring over it with correct hole locations. But....finding a shop (I do not trust my own ability to get this done correctly) that can precisely position the reinforcing ring, then weld it into place exactly where it must be to prevent the wheel from being lopsided once mounted onto the tractor hub, probably not many near where I am located. Not to mention, this would be a costly procedure that would yield a final result far inferior to making a new flat disk wheel.
After kicking this one way or the other then back again.....for me the best solution, when considering cost and quality of end result, will be to go with the new flat disc wheel using a 12X16 rim. It will be strong, sized correctly, have powder coated paint and will look good, too. Like you, I have searched far and wide for a very long time to locate a set of wheels like those shown on the tractor photo you posted. Oh, I did find a set at a salvage yard whose name I will not post here, but they insisted on $750 for the pair plus shipping. That price is $200 more than having a custom set made that are arguably superior. So, they are not a contender.
Getting back to the 10X16 option you have found for a much lower price. If your tractor is 2WD instead of the critical 4WD model, its certainly an option that, depending on your tire, could be fine. 4WD is fussy about tire diameter, as the correct gear ratio needs to be maintained between rear and front differentials. Mounting a tire on a rim narrower than recommended will increase the overall tire height and rolling diameter, an outcome which might impact that critical rear/front gear ratio. If your tire is like the one shown in your photo, the narrower rim will cause the center to bulge outward a bit more than when using a wider rim, but not all that noticeable due to the tires profile. However, if you are going to mount a tire with a flat tread profile, you will not want the center to be bulging out due to the rim being narrower than recommended by the tire manufacturer. The rounded profile of the Farm Service Dia tire shown in your photo allows for some deviation from the recommended rim width. But, unless you have a set or can find a set of used, the FSD tires are no longer manufactured in 13.6-16 size. From my own research, a wide turf tire in that size is now limited to only one manufacturer, which might be Carlisle, but not for certain.
Well, thats the scenic tour of my own journey in making the conversion from ag wheels to turf wheels on the Bison S670D. Oh, here is one last thought, but this one about the front wheels. 6X14 wheels with 6X6 bolt circle and a 4 5/8 center pilot are common. And, they will fit onto the front of your S670D. BUT, they are oversized for a 6-14 Farm Service Dia tire, which is still currently available. Another BUT....if you want to simply mount a 185R70-14 auto tire on this 6-14 rim, the height of the 185R70-14 is identical in height to the 6-14 Farm Service Dia, which is 24.2 inches. This option is fairly easy to put together and costs far, far less. For a 2WD tractor that may only be used for mowing, it should be just fine. Not, however, a good choice if those front tires are going to be subjected to heavy weight as when a tractor is equipped with a front end loader. Then, heavier tires are of course preferred.
Vvm
/ Turf rims for Bison S670D #10
When someone says "bison" I think of Prinoth. Funny so many manufactures use that name.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
Toro z turn (A56859)
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
43024 (A59228)
43024 (A59228)
