A36 vs AR 450 for Grapple
   / A36 vs AR 450 for Grapple #1
Logan979
Member
Kubota
which is better steel for a tractor grapple ? I am not a welder or metal man.
   / A36 vs AR 450 for Grapple #2
The AR will allow you to use a thinner material for equal strength and provide better wear resistance ( AR stands for abrasive resistant). It is much harder to bend then A36 at equal thicknes, this allows the grapple to be lighter for a given strength.
A36 is pretty much used by companies trying to save money as it's a little cheaper than AR plate.
To give you an idea of the difference:
A36 has a yield point of 36,000psi and a tensile strength of 58-80,000psi
AR400 (I don't have the 450 specs on front of me) has a yield point of 145,000psi and a tensile strength of 177,000psi. The 450 will be just slightly higher.
The number for AR plate refers to its average harness on the Brinell scale, ex. AR400 can have a Brinell hardness of 360-440.
great reply ! Thank you TMGT
   / A36 vs AR 450 for Grapple #4
If you are going to use a grapple with rocks or rocky ground, I would suggest one built with AR steel.
If you are going to primarily move bushes/trees, A36 steel will be fine.
An equally capable grapple, built with AR steel will have a lighter weight than one made of A36.
I don't have a grapple, and have never seen an EA grapple,...... but EA does build the best of everything,...... if you are willing to pay a bunch for the best.
   / A36 vs AR 450 for Grapple #5
Are you using it on a 100 hp tractor or a 20 hp tractor. For what and how often. Commercially?
My junky Grapple is just made of regular steel, and I have not managed to damage it in any way on my wheel loader. We have a lot of rock here too.
A friend with access to a laser was going to make me a grapple too and I worried over material. A lot of anxiety over nothing I think.
Kubota L3901 37 HP, going to attempt to remove a few acres of Rhododendron and small pines. No commercial use.
   / A36 vs AR 450 for Grapple #7
All of the commercially made “good” grapples are made with AR steel, some AR400, others AR450.
Cue someone giving an example of a good grapple made from tin.
   / A36 vs AR 450 for Grapple #8
All of the commercially made å*µood grapples are made with AR steel, some AR400, others AR450.
A36 steel is just fine for homeowner grapples.
AR steels are definitely best for commercial/every day use.
   / A36 vs AR 450 for Grapple #9
Not to hijack this thread but ... how does welding effect the strength of AR materials? My understanding is that is very little effect on A36.
   / A36 vs AR 450 for Grapple #10
I believe if you don't use the correct filler than yes, it will effect the strength at the weld joint.
New/Unused Mini Skid Steer Auger (A54865)
New/Unused Mini...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A54865)
2002 Ford F-550...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
UNUSED HURRICANE HF480 ROTARY DRUM SCREEN (A52706)
UNUSED HURRICANE...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
