richarsm
I'm having a bit of analysis paralysis here. We recently bought a house in Michigan, and I'm in need of a tractor. There's 14 acres total with ~5.5 acres of woods and ~8.5 acres of grass. Not fields, but more like finished lawn. I have attached a very crude picture of the property for illustration. It is a relatively flat piece of land. I need the tractor primarily for snowblowing and maintaining 1000' of driveway. Ideally, I'd like to use it for mowing the open areas as well, but I realize I will also need an additional machine to mow around the house. I was originally thinking a B2650 would be a good do-it-all machine, but I'm pretty well convinced it's too small. I also test drove one and detested the treadle pedal arrangement. I find the pedal on the Grand L much more acceptable. As of now, I've narrowed down the search to a JD 3039/3046R or a Kubota L3560. The Kubota looks to be a larger and much more stout tractor and weighs about 600lbs more than the JD. The JD is obviously lighter and I assume a little more maneuverable. I don't think tractor weight will play in my favor here as ground engaging work will be relatively limited. Is a Grand L too heavy to finish mow what is essentially lawn? I could add more to this post, but I'll leave it at that for now.
