Shipping Container Shop
/ Shipping Container Shop #1
Wyobuckaroo
NW BC CANADA
John Deere 2032R
So I been thinking..... At times my Sweetie would say... "Now what ?"
I'm thinking it would be quick, easy, and hopefully economical to build a storage, shelter shed from shipping containers.
I want rodent and bear proof storage for livestock feed, hay, other equipment and directly out of the weather storage for implements and such.
For instance the one in the picture is super simple. It would be nice to have the full slab under it like the photo has, but not necessary. A pad at both ends of two, forty foot long containers. Depending on standard rafter lengths available, the containers a minimum of 12' apart. Rafters can be easily anchored to the containers with angle iron and bolts. Close in the gable ends and back end. Of course snow load here in the far north is a consideration.
Anyone done this ? Seen it done ? Thought of doing it ??
Facts, details, helpful info ?
/ Shipping Container Shop #2
I would set them on blocks that way it easier to level them after freeze, get some pressure treated truss's made they can span 40 feet, want 24-30 inch eve, at 48 overhang at the container doors. Road millings have them oil and roll it.
/ Shipping Container Shop #3
Major and really the only complaint I've consistently heard about container shops is condensation if they're not insulated and ventilated correctly. I'd have a setup like that in a minute.........Mike
/ Shipping Container Shop #4
I think it's all about what you can get the trailers for and their condition. I see prices of 5K or more, not in great condition, easily open to the rodents you want to keep out. That makes 10K plus the other materials, so 15K or so.
I can build a shed for that and include dry/safe storage.
Maybe if you can find trailers for less ....
/ Shipping Container Shop #5
2nd what mrmikey said. I have one of these shipping containers and it is awesome for storage. Waterproof, windproof, rodent proof even! That said, I can only be in there with the door open for about 10 minutes because the air is so stagnant. Mine even has an air vent. I would not want to work inside one unless it had windows and a lot more ventilation.
With the setup like you have pictured, you could use the container as storage, tools, materials, and build the shop between them. That seems like a great idea!
/ Shipping Container Shop #6
I've worked in shops set up like this. It's ok untill you set up a work bench in one of the containers. Then you are forever opening those doors to work inside. (By the way make sure you buy containers with good doors.) I like the idea of a shop made like this but I would install a good rodent proof metal walk in door to the inside of the main shop part. You will be thankfull many times over.
Edited to add that I would put the walk in door approximately in the center or towards the rear of the container. They are long and narrow. When you start to use them for storage stuff gets piled up. (Good shelves help with that.) If you are looking for something in the rear of the container you have to go through all of the front stuff to get to the rear. A center door helps alleviate that.
/ Shipping Container Shop #7
There's a few threads on shipping container shops here on TBN. Search around for them. Good reading.
/ Shipping Container Shop #9
around here you could get 1 trip containers for under 5K
its endless what you can do with them
/ Shipping Container Shop #10
Hello,
I have seen a lot of tv shows about people building houses from shipping containers. It sounds good, but if you are going to put on siding, a fake roof, have to insulate it and put in good windows, you might as well build a house from scratch. That way, you can configure it the exact way you want it. I saw a show the other day that the guy who was building a container house was kind of disappointed when he got finished. Cutting holes for access to other parts of the building and for windows is not easy work. In your case, I understand the rodent and bear proof part, but those containers are pretty narrow for a well laid out, working shop. Just my view point. Good luck on whatever you decide.
MFWD
/ Shipping Container Shop #11
I built a shop from two containers about 15 years ago, give or take. I bought the containers to store stuff when I wasn't there because they where fast, affordable and fairly secure. After a year of working on the land I built a roof over them and walls between them. It was fairly simple to do, but not something that I would do again. They make poor walls and it's always a pain dealing with what's inside the containers. If you have the time, it would be much cheaper and better in the long run to just build a normal pole barn.
After my divorce, I created a small living area off of the side of one of the containers. I think it was 12 by 40.
Here are a few pics.
/ Shipping Container Shop #13
If you are not fussy, containers fit the bill. If you get fussy, I think containers quickly don't make sense anymore over conventional construction. I have 1 40 footer that I got for free, just had to pay for transport. Good for storage of stuff you want out of the weather, but not delicate stuff. Great for remote locations. As a shop? Why would you bother? Becaue it's a fad or trend, isn't a good answer.
The dimensions of containers really suck. They were after all designed to go down the road.
/ Shipping Container Shop #14
I have a 24' wide garage and sometimes bump into stuff moving 8' boards around. I don't think I'd want a storage container for a shop. I might want one for actual storage, though.
/ Shipping Container Shop #15
I posted on another container barn thread about my plans. I'm currently clearing a location to move 2 20' containers that we currently own and I'll buy a 40' high bay to go along with them. I want to have indoor storage for a tractor, a travel trailer and a couple of boats and to utilize the containers for small equipment and tool storage.
My plan is to put the 20'ers end to end and then offset the 40' HB 35'. 36' 4/12 trusses will sit on pony walls sized to give ~13 or 14' clearance under the bottom chord. I'll build a smaller pitch roof that will cover the containers and extend out to give a 10' cover storage areas. This will give 1400ft^2 inside barn area, 640 ft^2 container area and 800ft^2 covered storage. The containers will sit on poured in place beams with piers down a few feet and have embedded steel plates to weld down the containers.
Here is where i'm at on my design. I have been thinking wood for construction but after speaking with a buddy who is in the metal building business, it might make sense to get a different welder and build with steel.
/ Shipping Container Shop #17
Why not put the trusses at the edge of the containers for more covered space? Is it for appearance purposes?
/ Shipping Container Shop #18
I would put them on the inside edge and raise them up enough so that you can just continue the roof line to the other side. It's storage that is very inexpensive compared to the cost of the rest of the building. When containers are set up close to the ocean they will rust through on the roof if the roof is just left flat like a container.
/ Shipping Container Shop #19
That's what I was kind of thinking. I guess it depends on how much more wider trusses are. Saves you some framing if it's cheap enough. Nice thing about this design is you don't get rain and snow dumped in your opening.
/ Shipping Container Shop #20
Having the trusses on the inside wall will provide more wall space, which allows for more accessible shelving.
Having the trusses on the outside wall creates a large area above the container that will allow for more storage that will more then likely result it "stuff" ending up that is never seen again, or remembered that it existed. For me, I would think of it as a giant dust catcher where snakes go to to remove their skins. At least that's what I found with my container barn.
I would build the wall up from the inside container and extend the roof over the container just like it is in the Sketch Up drawing, and then max out the insulation over the container.
2015 John Deere 825i S4 Gator (A61166)
2015 John Deere...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
New/Unused AGT Flail Mower for Excavator (A61166)
New/Unused AGT...
2013 Chevrolet Impala Sedan (A61569)
2013 Chevrolet...
PALLET OF (3) BURNER GAS COOKER (A62131)
PALLET OF (3)...
