90cummins
Geez, I only have a generator.
When I could have had a Powerhouse.
Seriously impressed by that install.
Now if we could figure out how to get fuel in a crisis, that's the remaining issue.
I have 800 gallons of propane, but even that will run out even with rationing.
With the heat and humidity here, plus it gets cold here for sure, high demands on HVAC,
and since two of my heaters run on propane, the heaters are sucking up my gen fuel, not a preferred situation.
That install rates a nice Powerhouse sign on the door.
Thanks
Wood is our primary heat source with oil & propane as backup.
There痴 always a couple hundred gallons of oil on hand so it was the obvious choice for me.
Plus I was tired of the stale gasoline issues.
90cummins
