Winches self release snatch block problem
/ self release snatch block problem #1
Hoobie
New Brunswick Canada
Kubota mx5100 Ford 641
Hello friends. need advice.
I have a Kubota mx5100 as well as an old Ford 641. Wallenstein logging winch. I have been doing firewood operation for 40 years and finally purchased an Igland self release snatch block. I used it for the first time yesterday and had problems. instead of releasing the choker slides usually just jammed up against the pulley instead of tripping the release. Tried different angles, heights and even upside down. What am I doing wrong? Any help is appreciated.
/ self release snatch block problem #3
Hmm, picture of your chokers? Wire diameter? The release is not to stiff and tight?
/ self release snatch block problem #4
To me it looks as if a collar or choker that secures log should release cable guide and block should drop free unconditionally... Would believe it may have a bind at guide pivot point or choker is not shaped/guided proper to trip the cable guide retainer...
Dale
/ self release snatch block problem #5
I am sure you are rigging like this ????
In looking at the Ingland block picture I see here: https://www.ebay.com/i/113734223555...xauu0T7LEe3GsNQSXzvc-d9zzYuOkyVBoCs68QAvD_BwE
I see what might be a problem. There has to be room enough for the slider to run around the sheave in the groove w/o binding on anything. If the slider hits a binding point before the trigger it will jam. To me it looks like that block/spacer that is under the trip lever does not leave enough room between it and the sheave for the slider to pass by. I would look at that closely and maybe find some smaller sliders, or make a small dummy slider thing you can put on your cable so it hits the snatch block first and can pass thru that space to trip the lever, or just grind back that spacer - I don't know why it is so long but there must be a reason I don't see so go a little at a time.
gg
I have 3/8 cable with standard size sliders. The release arm works freely by hand. The slider usually never gets to the release arm but butts against the pulley and stops. Not pulling anything excessive.
/ self release snatch block problem #7
Try rigging with the part of the snatch block that has the release arm facing down toward the ground.
/ self release snatch block problem #8
I think if you look close you might see that the slider is butted against the pulley and that rectangular block spacer under the lever so it can't enter the pulley to trip the lever. You need to correct that interference or make your self a smaller pseudo slider thingy that won't jam against that spacer but will swing the lever.
gg
/ self release snatch block problem #9
I own this type of snatch block and never had any trouble like this, pic of the sliders?
/ self release snatch block problem #10
That is good - you will be more help to him than me. I am just guessing on how it could jam. I agree that pictures are needed.
gg
I tried the picture. Never did it before. If I fail will try again. Any ideas for a dummy or pseudo slider.?
/ self release snatch block problem #13
What exactly is your slider jamming against? can you take a picture of it when jammed? I've got two different self-releasing snatch blocks (unfortunately, neither are identical to yours). I've never had a problem with the sliders just jamming against the pulley and stopping,
/ self release snatch block problem #14
I have the same s/r block, no problems. I may have smaller sliders (for 3/8 max) chain chokers, but you do need to use it with the wheel facing down.
/ self release snatch block problem #15
As mentioned, rig it up again, and take a picture of it as it's rigged. Maybe that'll show a problem for the guys that use them.
Ok. In a day or two when I am out again I will take a picture. Thanks all.
/ self release snatch block problem #17
Is that specific to this s/r block or is that for all of them. I have used mine both ways and never had a problem releasing, but maybe I have just been lucky. Always wiling to learn more.
Doug in SW IA
/ self release snatch block problem #18
Doug in SW IA
Actually in this video made by Igland they clearly show their s/r s/blk set up with the open face up. So there you go - intuitively you would say facing down would be better because the cable would have less chance of fouling coming off the sheave but there is not much for it to catch on if it is facing up. So either way works..
Igland Snatch block with automatic release - YouTube
It will be interesting what Hoobie's problem turns out to be.
gg
2015 John Deere R4038 Sprayer (A63109)
2015 John Deere...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
2023 Kubota KX057-5 Compact Excavator (A63118)
2023 Kubota...
