Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s
   / Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s
I'm still looking for the 'dozer' blade in this thread.
Ohhhh... sorry bout that, you youngsters aren`t familiar with the older terms of what things used to be called :duh:
I've been using this 8' plow setup for 20 years or more. Added a rubber scraper this year because of the 800' of new concrete in the driveway.
In high gear, the tractor isn't even warmed up by the time I'm done. 2 passes and lights out.View attachment 627599View attachment 627600
VERY NICE!!!!!! Where did you find the rubber scraper (?)
   / Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s #14
THIS is a dozer blade.
What you have is a snow plow blade.
Looks like it worked out very well. I enjoy seeing projects that adapt and use things that some people wouldn't think of.
One question though. Will the BX need to take anti-rejection drugs? :)
Thank you... yeah it was quite a task thinking how it could be done, then buy what i needed, then putting it all together. It works amazingly very well! :drink:
Anti-rejection drugs.... BAAAAAAhahahahahaha, you thought of something i never even given much thought about.... i`m gonna have to look into that for sure...lol.
One thing i did worry about though, was all the red trans fluid had to be flushed out from the cylinders. Didn`t need that mixing with the Bota blood and infecting it :)
I was able to flush the cylinders out with solvent, used low air pressure to blow all the old Deere blood out of the cylinders until it was clean.
Thanks... i think everybody gets it. Excuse me for not being 100% politically correct to your standards.
   / Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s #17
It is splitting hairs a bit, but despite looking similar a dozer blade & snow plow are reasonably different. A true dozer blade is WAY stronger. A snow plow is up to pushing dirt, especially not anything packed. Dozer blades are also mounted further back on the machine so they don't bounce & cause washboard. Some tractor mounts connect the plow subframe further back but truck, riding mower & a lot of tractor mounts dont.
We get it we get it we get it. Nobody cares... Give it a rest.
   / Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s #19
   / Who Says You Can`t Put a Dozer Blade From a John Deere on to a Kubota BX23s #20
Well he is right. Do you call your chainsaw chains blades?
Non- Running Falcon Fang 125 Four Wheeler (A57453)
Non- Running...
2021 Deere 333G (A53317)
2021 Deere 333G...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2018 CON-WAY DOLLY (A59575)
2018 CON-WAY DOLLY...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
