Kubota Regeneration
/ Kubota Regeneration #1
Will_C
Upstate N.Y.
Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
Have had my L3560 for about 15 months. I have 150 hours on it. It has regenerated 6 times-each time has been around 25 hours plus or minus an hour or two. I was just wondering about others experiences. Probably 80-90% of the hours have been at 540 PTO speed using a RFM, a tiller, or a bush hog. Is this close to what people are seeing with their Grand L's?
Thanks,
Will
/ Kubota Regeneration #2
Yes, what you are describing sounds about right.
/ Kubota Regeneration #3
2019 Kubota 7060HD12. First regen at 27 hours, and second one today at 54 hours.
/ Kubota Regeneration #4
My L4060 has gone through 6 regens averaging 54 hours between. Mostly loader work, occasional mowing at PTO speed, and maybe 20 hours of winter plowing per year.
/ Kubota Regeneration #5
About what I've seen on my L4060 at 350 hours or so. Maybe 20ish hours between regens. No issues at all emissions wise.
/ Kubota Regeneration #6
A tractor mechanic told me if one is getting 25-30 hours between regens they need to stay with their fuel supplier. He said regens has really been a headache for repair people in trying to reduce regens for people trying to use the cheapest fuel they can find if it is labeled for a diesel.
/ Kubota Regeneration #7
Has anyone tried those additives for DPFs? I've seen on other forums, people using this stuff with very good results. It helps with the regeneration process.
This one is from CRC but for some reason is only listed on the EU site and not on the US site.
CRC WebSite: Product Detail
Liqui Moly also makes a similar product that works nicely.
Thanks to all who replied. It makes me feel better that my intervals are on similar to others. I don't know anyone with DEF tractor, so no information there.
Thanks
Will
/ Kubota Regeneration #9
I wounder if anyone has ever worked right through a regen. process and not even realized it? Is a regen. count clocked on the tractors electronics for viewing?
/ Kubota Regeneration #10
I have worked thru the cycle on mine a coupe of times. Did not know it was doing it thing until I smelled the brunt paint smell just befor it got over
/ Kubota Regeneration #11
Same here I've worked through my regens and the only reason I know is the funny smell it makes or a different sound it makes when I'm using the loader. If I were to guess at the frequency it would be every 20 to 30 hours. I run a M7060 12 speed. I be had it two years last June with 1600+ hours. No complaints.
/ Kubota Regeneration #12
Mine did it's first regen this week and it was a total nonevent. Was running the RC and if not for the flashing dash would not even have known it was doing it. It was right around 26 or 27 hours. Took 11 minutes while I kept working and it was done.
/ Kubota Regeneration #13
I'm a recently retired 30 year diesel mechanic. My advice to anyone who owns or plans to buy a tractor with DPF is sell it and don't look back. As these systems age they become a nightmare that will cost you both time from getting the job done and money. The systems that use the DEF additive aren't any better. The trucking industry is suffering because of this Government imposed crap. And just for the record, I'm not a right wingnut, global warming denier.
/ Kubota Regeneration #14
You are preaching to this member of the choir.
I searched for months, and bought a 2006 model, 250 hour Kubota L48,..... SPECIFICALLY to avoid the government mandated crap.
/ Kubota Regeneration #15
I’ve got about 1,500 hours on my tractors with DPF. Many have been noticed only by the flashing yellow light or seeing the DPF percentage at the end of the day. I have no change in sound and certainly no odor. Happy to be rid of my smokers, wish I had the $$$ to replace combine and mini-ex from which I now find the stench really annoying. Oh, right, added to the stench by buying an old diesel pickup a couple months back, also because of not making business sense for me to buy new like I wanted.
/ Kubota Regeneration #16
Bingo, Mike.
Thanks, feds.
SDT
/ Kubota Regeneration #17
The exhaust on my fancy pickup with DEF and DPF is worse then most older diesels I have been around,
It is difficult to unload from the bed if it is running from the fumes.
Now an old tired diesel with leaky injectors pumping black smoke when not even being worked can be real bad to be around also.
But a decent running pre emission engine is not bad to work around.
/ Kubota Regeneration #18
Close to the same interval here. Kubota MX5200.
/ Kubota Regeneration #19
Put a clothespin on your nose......:D
/ Kubota Regeneration #20
Also being a retired diesel mechanic (Freightliner) and having to smell the stench emitted from an overdosing DEF engine, I can relate. I'd say before I retired that about 85% of our shop work was failed or failing emissions hardware and software with DEF dosing issues being at the top of the failure list. Second would be sensor fouling and third would be EGR issues with hard carbon deposits.
Replaced a few 'one boxes' too. The one box is a stainless tank affair that contains all the emissions related hardware and is very similar to what Deere is using on their Tier 4 final ag tractors. The cost of a one box without the 'guts' is 10 grand and they do fail just like the rest of the T4 final hardware.
I guess if anyone makes a statement to the effect that they prefer it, I say, whatever blows your dress up because it don't blow mine up at all. I guess it you 'think it's a good deal' maybe you should invest in a plug in electric tractor and see how that works out.
John Deere Sign (A64557)
John Deere Sign...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
